- Bad Coolant Sensor
- Car Scared Me Today!
- Power Steering Pumps
- Not A Ordinary "car Won't Strat" Thread
- Fuel Injectors?
- Never Again....
- Manumatic Ftw!
- Spark Plug Seal Gasket
- Flex Pipe Question
- Crescent Seals Under Valve Cover
- New Exhaust=bad Idle
- Beta II Oil Pan On Beta I
- Flex Pipe Size On 97 Tib
- Top To Bottom Rebuild- Were To Start-were To Get
- Car Running Poorly, Is It Fuel Injectors
- Idle Problem, Help
- A Elantra Question
- Vehicle Bogging Under Wot?!
- Beta I Vs Beta Ii Engine
- Break In Period
- Bad Shifts
- Belt Question
- Shaky Clutch
- Catalytic Converter
- Good quality wires?
- Cai Suggestion
- How To Tell Cams?
- N/a Engine With Intercooler
- Question: Flywheel Crank Size: 2000 Tiburon - Rd2
- Poor Acceleration
- Check Engine Light :)
- Beta 2 Valve Cover Problem...
- Debate On Oil Coolers.
- Put Another Tranny In W/xdt Stage 2 Clutch
- Manual Tranny Fluid
- Leaking Engine Bolts
- Have You Guys Heard Of This Oil Plug Replacement?
- Oil Drain Plug Seal?
- Building N/a Motor
- Self Install 5spd Tranny
- Arc Welder For Exhaust Work
- Is This Transmission Guy Serious?
- Houston, I Have A Problem!
- Timing Belt Question
- Electrical Power Woes
- Auto Tranny Max
- New Product I Made: Jattus Vacuum Hub, New Design (powdercoated Fittings)...
- Oil Burning Survey.
- Won't Accelerate Until 4000 Rpm
- Beta 2 Tranny Swap
- Timing Belt
- Squeeling Belts - How To Adjust Drive Belts
- Not So Good.. Just Started The Car Up.
- Rough Shakey Throttle
- The Best Timing Belt
- Tick, Tick, Tick....
- Anyone Know The Exact Model Of Quaife Lsd For Gen 1?
- 1.5l Cams?
- 02 Sensor
- Oh Dang. First Major Casualty *pic*
- Air Ram Design?
- Clunking Noise Shifting From 1st To 2nd
- Rside Advanced Shifter And Stock Stupid Bushings..
- Tranmission Counterweight.
- Overdrive And Underdrive Pulleys On Ebay(haha)
- Shark Racing Thermostats Good
- Oil Burning
- Which Pulleys
- Timing Belt And All Other Belts?
- Act Clutch And Fidanza Flywheel
- New Rail Is Done!
- Dumb Question About 1.8l Cams
- Anyone Interested In Capped Manifold Bolts?
- Remove Rev And Speed Limiter
- Xtd Clutch?
- What Kind Of Socket Is This?!
- Only Clutch Disc Change
- Help Me! Exhaust Stud Specification
- Help! I Cant Seperate Me Tranny From Engine
- Clutch Install Problem...
- Generic Ebay Cold Air Intake
- Xtd Chrom-moly Flywheel
- Death Of The Tranny?
- More Tib Problems
- Performance Ecu
- Vacum Problem
- intake manifold from another car?
- Clutch Problem
- Turboing My 98 Shark
- Need Some Help,
- Clutch/flywheel Setup Question...
- Gear Slip
- Downshifting Into First On Rd2
- Auto Tranny Ideas
- Clutch Pedal
- Oem Pressure Plate?
- 3rd Gear 5,100 Redline
- Installing New Hla's
- Dual Throttle Body
- Clutch/flywheel Assistance
- Other Tranny's For The Beta?
- Installed 1.8l Cam Yesterday...
- Interest In Certain Parts..
- Need A Part.. But Dont Know What To Call It.
- Grinding During Shifting
- Engine Issues
- Transmission Wont Come Off! Help
- Clutch Issues
- Gear Ratio In 1.8tib Vs 2.0 Elantra
- 3" Maf Intake Piece
- Low End High Torque Cams
- Quick Question
- Kspec Mounts
- Finally A New Motor
- Starting Trouble...good Battery.
- 1.8 Piston Dimensions
- Help! Changing Belts!
- Rd1 Engine Size 1.8/2.0?
- Rice Performance, Painting Rad. Hoses.
- Ever Seen This Intake
- Window Welding My Roll Stop Mounts
- Shifter Base Bushings?
- Exaust Headers (which One)help Me?
- Wideband O2 Output Cable Vs Ecm
- Installing Pistons
- Car Stalls At Wot
- Got My Clutch, Flywheel Kit.
- A Bit Of A Problem
- Atf Change/flush
- Car Troubles Need Help
- Need Help Diagnosing Problem.....
- Just Finished Checking Compression..
- Help Me Out, My Car Is Idling Very Rought And Has A Cel
- Next Move In The Hp Game
- Automatic Transmission - Shifting Problem
- Clutch Friction/catch Point?
- I Want This...
- Bought My Self A Manual Transmission!
- Throttle Body Spacers
- Cai
- Confused On Manifold Recall
- Are These Hp Ratings Even Close?
- What Clutch Should I Get?
- Oil Leak Problems
- Do You Have A Leaky Power Steering Hose?
- Slice N Dice.. Please Help...
- Is Anyone Using An Aftermarket Timing Belt?
- Cv Shaft Transmission Oil Leaking.
- Distiguish Cam?
- Best Clutch?
- New Clutch
- Transmission Is Owning Me :(
- Issues...need Help...
- Bbtb Help
- Cams, A Few Questions.
- Measuring Lift
- P1613 Tcm Mil
- Oil Pan
- My Project This Weekend....
- Tps Or Not?
- European Rd Vs. Us Rd Ecu
- 1999 Gt V6 Ina 98 Fx?
- Help! Axle Seals
- Header Cel Fixed!
- Trying To Register At Flyryde
- Doing Some Calculations
- Timing Belt Changed
- 1.8l Pistons
- Broke On Way Home From Track... Whats The Deal
- Thought I Bought A 1.8ecu
- Goddamn O2 Sensor Bungs...
- Ark Sts Problem :(
- Where Is This Squeel Coming From ?
- In Search
- Clutch
- Auto Tranny Guys
- Help Cel Light On And Bad Gas Mileage
- I Need Some Help
- How Much Oil In The Tranny
- Help Please 5th Grinds
- Weird Noise At Idle
- Obx Lsd?
- New Clutch - Question Regarding Engagement
- Mounted Fpr (update 9-30-06)
- Clutch Alignment Tool
- Whats My Problem?
- Megan Shifter Problems?
- Got My Hands On A Beta2
- Clutch Broke - Back In The Shop Again..
- The Tib Is Acting Up Again
- Looking For High Comp Pistons.
- Bad Clutch?
- Vote On What Looks Best. (muffler On Tiburon)
- 2.4l Kia Engine
- Car Hesitates
- Engine Specs
- Tps Problems
- Need Help With Wierd Problem.
- Is My 2nd Gear Coming Out?
- Oem Vs Obx Pulley/timing Gear Weights
- Removing The Clutch Fluid Restrictor
- Possible Water Ingestion
- What Could It Be?
- Tib Just Dies!?!
- To Swap Or Rebuild, That Is The Question.
- Lsd
- Diy Motormounts Install
- Release (throwout) Bearing Gone!?!
- Kspec Xd/gt Cam
- Fuel Pressure Concerns
- Nopi Headers
- Fuel Pressure Gauge
- Dirty Coolant
- Engine Running Wierd... Help!
- Valves Tapping Away
- Hyundai Technical Bulletin
- Help Please.
- 2001 Tuburon Se !help!
- Overheating Again... Arg
- Engine Ticking?
- Alpha/beta
- Xd Cam Timing
- Oil Pan?
- 4g63
- Aftermarket Ecu
- Individual Coils - How To Wire Them?
- Increased Spark Plug Gap!
- Manual Tranny Swap-part Compatability
- Engine Balancing
- Oem & Jspeed Pulley Weights - Belt Sizes
- Coolant Flush
- Rebuilt Motor, Won't Turn
- Clutch Feels Like It Is Weakening
- Whats That Noise!
- Tranny Problem In A 2001 Lantra
- Clutch Pedal Loose...
- Act Clutch
- Jenvey Quad Throttle Intake
- Wierd Idle Problem
- Looking For Help On Clutches, Just Replaced Mine
- Cel 0121, 1127 Leads To 0102/3
- Has Anyone Had Their Timing Belt Changed At Non Hyundai Service?
- Fidanza Flywheel + Cams + Turbo?
- Is It Worth My While?!?
- 02 Sensor Issues
- Interference?
- Manual Tranny Questions
- Upper Chain Guide
- Broken Transmission?
