Rough Shakey Throttle
Vehicle: 01 Tiburon SE
crappy news, fender dont fit so have to take it to a body shop and actually get them to fix it all 02.gif more money
alright well before the accident, like september, the car idled somewhat fine, but every couple minutes it would sort of dip for a second and then go back up making the car shake
now that i got it back its even worse then i remember it, idles at around 900 - 950 if i had to guess by looking at the tach and it shakes like bad now... and also when i hover my foot over the clutch it pulses pretty quick, and dont remember that happening before
pretty sure i can just raise the idle to sort of fix the problem, but what about the pulsing clutch and dips in idle?
thanks guys
thanks guys
Vehicle: 2009 Hyundai Sonata
this has been discussed many times but here are some of the causes:
1) bad TPS
2) clogged up PCV
you could try PCV first, as it is a cheaper replacement. if the problem persists, look into purchasing a new TPS
1) bad TPS
2) clogged up PCV
another thing you should do that would be cheap is to buy yourself a bottle of intake/throttle body cleaner, and a package of red rags, and spray the bajesus out of your throttle body (engine off) and wipe away all the carbon buildup and clean up your throttle body and plate. it may or may not aid your problem, but it's cheap and is a generally good maintenance for your car. speaking of which i should do mines too.
^^^ Engine mounts may cause a harsh vibration, or even a slight vibration, but shouldn't cause the irratic idle.
HA! no particular benifit from the red rags, that's just always been my choice of cleaning towel/rag, whatever works for the job.
QUOTE (DrivingTibNaked @ Dec 10 2006, 11:15 AM)
^^ is there a reason for "red" rags? I usually use blue shop towels from walmart (rags) for everything.
