PDA
View Full Version : Engine, Intake, Exhaust
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Exhaust Cam Pulley
  2. Cel If I Drive Like A Granny...
  3. Short Shifter Thread
  4. Korean Ecu Better?
  5. Fpr Fuel Pump
  6. Sending The Tib To Level10
  7. Clutch Pedal Vibrates
  8. Jspeed Crank Pulley / Airram Measurements
  9. Thermo Block Spacers Aka Phenolic Spacers
  10. Why The One Step Colder Spark Plugs
  11. Need Complete Tranny Swap Parts List
  12. Bad Maf
  13. What Do You Think
  14. Oil Pump Failure???
  15. Bbtb List And Sizes
  16. Larger Injectors!
  17. Tigerlily Bbtb
  18. Damages Of Lean /rich?
  19. Car Likes To Idle Poorly On Occasion.
  20. Got A Cat-back!
  21. Fuel Pump (in Tank)
  22. Cold Air Probs
  23. Catalytic Convertors?
  24. Slimline Fans
  25. Anone Have This Problem?
  26. When Did The Transmissions Switch
  27. Clutch Fluid Dirty Withen 1 Day After Change?
  28. Chipping The Stock 99 Tiburon
  29. Cel..... Need Advices...
  30. The Perfect Tranny Swap
  31. What I Did May 21-23
  32. Help, Funky Noise
  33. 4:3 Final Drive
  34. What Is Wronge Transmission Or Computer?
  35. Cruise Control
  36. Beta 1 Or 2
  37. Timing Belt ?
  38. Holding Clutch Pedal
  39. Maintenance
  40. High Flow Cat & Placement
  41. How Do You Change Your Transmission Fluid?
  42. The Better Choice*cai*
  43. Overdrive Kicking In On It Own?
  44. Header Install?
  45. 1.8l And 2.0l Engine Rebuild Kit Intertangable?
  46. Ebay Headers
  47. Won't Start
  48. Clutch Grabs Late
  49. Clutch Difference's Between Years??
  50. My Next Mod!
  51. Everyone That Has Put A Elantra Tranny In Your Tib
  52. Please Help With Cel!!!!!!!!!!!!!!!!!!!!!!
  53. No More Cotton/gauze(k&n Style) Air Filters For Me
  54. Afr Vs Performance, Economy, Pollution
  55. Compression
  56. What Do You Want For Normally Aspirated Power?
  57. Omg!! Super Pi$$ed!! Need Clutch Help!!
  58. 2000-2001 Tib Clutches?
  59. 2001 Tib Sputter
  60. Engine Swap
  61. Exhaust Ports Finally Revealed
  62. I Need Some Advice
  63. This Is What I Get For Hanging Out With Jaws021...
  64. Sawpping 2.o W/ 2.o
  65. Changing Spark Plugs
  66. Engine Build Pics
  67. Kspec Gb Racing Header Installed :-)
  68. Pulley
  69. Rad Leak
  70. Turbo Or N/a???
  71. Intercooler W/o Turbo?
  72. Some Engine Building Questions And A Couple Pics
  73. Help With Injector Install Diy
  74. Phenolic Spacer And Throttle Body Spacer..needhelp
  75. Attention Spec Clutch Users!!!!
  76. Another One Bites The Dust!
  77. Intake Air Box? What Is It?
  78. A Question About The Od In My Rd2
  79. New Trans Installed
  80. Clutch?
  81. Flywheel
  82. What Could Be The Worst To The Auto Tranny?
  83. 2000 Elantra & 1997 Tib Tran Harness
  84. Ark Short Shifter
  85. 2000 Elantra Tranny In A 97 Tib?
  86. Headers Question
  87. Pulleys
  88. More Motoria Exhaust/header Video Clips :)
  89. How Much Oil Do You Fill?
  90. Major Tranny Issue...
  91. Issues
  92. Voltage Spikes???
  93. Engine Holds Rpms Too Readily
  94. Short Ram Question
  95. What Transmission Oil ?
  96. Plug Wires
  97. What Fits?
  98. 2000 - 2001 Tiburon Needed!
  99. Alright Guys.. Need Help With Oil Change
  100. New Ecu, Maybe
  101. Airram Intake Manifold Update...
  102. Is Your Tib An Automatic Or Manual Transmission?
  103. Evaporation Cannister- Rev A
  104. Pulley Weights...
  105. 1.8l Pistons/intake Cam In 2.0l
  106. Cai Or Short Ram?
  107. Cel Strobe Light
  108. 1703
  109. Exhaust Question.
  110. 2nd Gen Transmission In A 1st Gen?
  111. Keep Going Through Throwout Bearings
  112. Ceramic Coated Gt Headers Installed - Picts, No 56
  113. Im And Bbtb California Emissions Question
  114. Beta 2 Swap
  115. Thinking About Swapping To A 2.0 L4 Motor
  116. Wich Clutch???
  117. Sometimes I Have A Low-end Torque Problems
  118. Engine Overhaul
  119. Wonderful 2nd Gear After Clutch Change
  120. My Car Is Dying.... I Need Help
  121. High Comp, Cams, Smt6, ...
  122. Clutch Sticking?
  123. A Few Sts Questions
  124. Gear Spreadsheet
  125. Obx Pulley's On Rd1 Help
  126. Transmission Fluid
  127. Ark Vs Mbrp
  128. Taking Out Air Filter
  129. Washing Engine
  130. Anyone With A Shop Manual
  131. Oil In #3 Sparkplug
  132. Shifting Question
  133. Problem With Shifting
  134. Won't Shift Into 2nd Gear
  135. Clutch Slipping= New Clutch
  136. Need Some Help With Find Out Whats Wronge?
  137. Another Questions About 1.8 Ecu
  138. Winter And Cai
  139. Big Big Problem, Slipping W/ An Auto.
  140. Bbtb Project, Everyone View This And Help!
  141. Valve Cover Gasket
  142. Redz Oem Mod
  143. Engine Iron Or Alu ?
  144. Ark Catback Finally Installed!
  145. What Mods Effect Gas Milage?
  146. Installing Exhaust...
  147. Automatic Transmission Maintenance
  148. Cam Problem
  149. Timing Belt
  150. Power Steering Problem
  151. Auto Trans To Manual Trans Swap
  152. Replacing Some Hoses
  153. Oil Leaking, Need Help
  154. Header/exaust/rside Ss Installed!!
  155. H/e Install Cat Help!
  156. Engine Breather
  157. Hyundai Fuel Injector Sizing.
  158. Installed Airram Intake Manifold Having Problems.
  159. Problem With Coils?
  160. Ticking Under Extrem Load
  161. 1.8 Head On A 2.0
  162. What Rpm Do You Shift?
  163. Can We Do This?
  164. Loud Ticking Sound
  165. Vibrations Still There
  166. Small Cai Update
  167. Rising Rate Fpr Install?
  168. Help!!!! Intake Cam Journal Bolt Emergency!!!!!!
  169. My Custom Cai :)
  170. What oil do you use?
  171. Sharkracing pulleys - HELP!
  172. Keelee's not shifting
  173. opinions about a transmission
  174. Anyone Install Haltech?
  175. My transmission just went
  176. Axle/tranny oil?
  177. Throttle body's
  178. Strange Knocking noise FIXED!!
  179. MSD DIS2 programable help and advice?
  180. I am beyond stumped..
  181. 1.8 cam and 1.8 ecu...... together?
  182. Need exhaust advice
  183. difference performance exhaust and cat-back?
  184. Queitest Performance muffler
  185. In the process of building a 2.0 beta I need some help
  186. window weld
  187. Need New Tranny??
  188. help with install
  189. 1.6ltr swap to 2.0
  190. Tuning the clutch
  191. rside install issues
  192. Car boggs
  193. GT Cam
  194. Crank walk
  195. Intake cam swap & ecu
  196. Check Engine Light & more... :(
  197. My exhaust update!
  198. engine dress up kit
  199. Upper Radiator Hose Leaking.. question.
  200. NGK Ignition wires Q's
  201. bad o2 sensor, could be this the problem?
  202. Shame On Me
  203. Strange knocking noises? help!
  204. trans axle went capoop
  205. Ignition fuse problems
  206. ARK Catback on sale
  207. Po134 o2 sensor 1......
  208. 1.8l Cam
  209. Check Engine Light...
  210. BBTB Problems
  211. Stalling at light..
  212. Better heads?
  213. Quick questions about IM
  214. SlimLine Fans
  215. another bogging down question!
  216. Question for SS owners
  217. Please help, Major Problems Bogging.
  218. 1.8 rods or headspacer
  219. removing slack from gearbox
  220. Clutch Moaning(lol)
  221. kspec BBTB
  222. Need help.
  223. Pistons from other cars?
  224. Beta1 vs Beta2 pistons
  225. Throttle Body Heater Removal
  226. funny ticking/scratching noise...
  227. Re: My custom intake
  228. Remap and Tune your stock ECU
  229. Transmission Syncro Types.
  230. shark racing short shifter
  231. Tranny/engine swap
  232. Is there a DIY for changing a clutch?
  233. ECU wiring diagrams help!
  234. another 1.8 ecu question...
  235. Has anyone heard about XADO?
  236. Bar's products, anyone use them?
  237. rd2 manual tranny fit in a rd1
  238. 1.8l ecu
  239. ClutchNet Stage III Clutch & Fidanza Flywheel.
  240. Flowmaster muffler question?
  241. header question
  242. manual tranny from '97 Elantra to '00 Tib?
  243. replacing belts
  244. tranny swap, What do you recommend?
  245. replacing drive belts (wear)
  246. ark n2/ apexi n1 catback
  247. dangling object under hood?
  248. Lsd
  249. PU motor and gearbox mounts
  250. Resonators?
