- Conversion
- Flywheel Bolts Too Small?
- Another Timing Question
- Mitsubishi Eclipse Tranny
- How To Detect A 1.8l Cam
- Fuel Pump
- How To Reset Timing On A Beta Engine
- Koyo Radiator In.
- Tib Exhaust
- 1.8l Cam And Cel. Please Help.
- Overheating Problem
- Still Trying To Fix The Prob.
- Phantom Grip "lsd"
- Hondata Intake Manifold Spacer
- Heat Shield
- Lsd Swap
- Tranny Whine
- Map Sensor
- The Clutch Install Ordeal, Finally Complete After 2.5 Weeks...
- 1.8 Cam Swap
- Pulled The Motor
- Clutch Question
- Tranny Question
- Chromoly Or Aluminium?
- Forged Rods.
- Sr Hi Cams
- Removing Throw Out Bearing?
- Bearing Caps
- Timing Belt Change
- Fixed My Sqeaking Clutch
- Motor Mount !
- Oil Filter #
- Transmission Filter?
- Broken Bolt For Oil Pan
- Update On Damage/build
- Transmission Removal
- Fans Dead.
- Tapping The Fuel Rail For Fittings
- 1.8l Cam Swap And Cel Problem.
- Question!
- Grip-force Clutches.
- Fuel Filter Replacing. Trust Non-hyundai Dealer?
- Apexi Website
- Cant Get It Into Second
- Pistons Shot?
- Exhuast For 01 Tiburon
- 1.8 In Place Of A 2.0?
- Fuel Pump & Injectors
- 2006 1.6l Tiburon Dead After Playing Ps2 Help.
- Exhaust Sizing Question
- Mobil 1
- Removing Main Pulley... Timing Belt Replacement
- Clunking...?
- Finding Top Dead Center
- Anyone Running A Ss Clutch Line?
- Radiator Hose Diameter?
- Rad Replacement
- Gear Oil
- Gear Ratio For Automatic And Manual Transmission
- Rd1 Tib, Worth Swapping The 1.8 For A 2.0?
- Clutch Question
- Hks Intake For The Rd2?
- O2 Sensor / Check Engine Light
- Cai Or Shart Ram?
- Temptation Has Come, Switching From Auto To Manual
- Increase Line Pressure (automatic Transmission)
- Help, Wires Broke Stuck
- New vs old
- Injen Intake
- Propane Conversion With Pics
- Overheating... Water Pump?
- Tps
- Air Ram / Tb Install
- My Clutch Noise Problem *pic And Video Included*
- So My New Oil Filter Is Dripping!
- Exedy Heavy Duty Clutch.
- Can't Find Reverse On New Shifter!?!?!?!
- Noisy Engine After Autox. Easy Fix?
- Adding HP
- Whats The Temp Range For Heavier Oil?
- Looking For A Maf To Map Converter
- Radiator Fans.
- Wheres The Oil Drain Plug ?
- Clutch Pedal
- I Need To Thread Something
- DECISIONS
- Exhaust Buzzing
- Ignition Coil Pack?
- Oil Build Up
- Question About The Exhaust...
- Gearbox
- Lots Of Play In Shifter
- Cam Help
- Tranny Swap Question
- Any Way To Patch Oil Pan Without Dropping It
- mods
- Performance Parts For Alpha 1.6l Engines From K-spec
- Completely Confused About Pistons...
- Heat Shield And Turbo Manifold Cover.
- Mitsubishi 4g92 Mivec Engine
- Help! Trans Problem
- Let's get this forum re-opened
- Bare Block Weight
- What Size Injectors Should I Use?
- Plug Wire Order
- Seafoam
- Engine Mounts
- Cant Shift Into Reverse
- Car Trouble...
- Idle And Acceleration Problems
- Atf Flush -- Which?
- Anyone Wana Split A Block And Head?
- Motor Swap
- Engine Cooling Issues
- Bored Tb *blng Bling*
- New Tranny
- Venom Ecu
- Aem Intake Loud As Hell?!
- Misfire In Cylinder 1 After 1.8 Cam Install.
- 1.8 Intake Install
- Tall 5th Gear
- Where To Buy Slim Fans? Fan Info Requested
- Auto Tranny Hesitates, High Rpm On Shift Sometimes
- Clutch Is Going, Questions On New Clutch.
- Questions About Pistons
- Headgasket/decomp. Plate Install
- Fidanza Cam Gear
- No More Idling?! 0_o
- Mass Air Flow Poroblem
- 2001 Problems
- Clutch From 97 1.8l To 98 Fx 2.0l? Need Help Asap!
- Gotta' Replace The Starter Asap!
- Rside Short Shifter
- Cheap Billet Oil Cap?
- Time Attack Tiburon
- 1.8l Cam Markings
- Tib Dying... Help Plz
- Lsd Inserts
- Problem After Phenolic Spacer + 58mm Bored Tb + Ported Im
- Beefing Up Your Transmission
- Valve Cover Gasket Leaking?
- Clutch And Flywheel
- Spark Plug Wires On Ebay
- Engine Boring
- Loud And Annoying Whine When Warm...
- Royal Purple Tranny Fluid
- Transmission Is Confusing Me...
- Altered Intake Manifold
- N/a Ecu Reflash With Hi Cam - Major Update Post #35
- A Couple Of My Oil Testing Results
- Rd1 Problems Re-arise, Stalling, Won't Idle.
- Stroker Kits "increase Hp In The Low-end"
- Water Pump
- Tranny Repair And Overhall Services
- Mt-90 Tranny Oil...
- Outlaw Thermo Spacers
- Beta Vs. Beta 2 Head Gasket - Interchangeable?
- Engine Is Stuttering
- Tranny Bushings
- My Shifts, Wtf
- Transmission Fell Out Of Car?
- A Small Dillema...
- Replace The Water Pump Or Not?
- Overdriving Accessories
- Guess What I'm Fen To Do.......
- Will This Fit...
- I Have A Auto 99 Tiburon Fx And I Want To Make It Manual ?
- Underdrive Crank Pulley Install Problem
- Anti-freeze Smell
- Clutch Fluid Replacment..
- Quick Tips On 97 1.8l To 2.0l Engine
- Syncro Problem Gone!
- 2.0l Or V6 3.8l
- Full Tune-up And Parts?
- Those With Bad Syncros.
- Tranny Difference?
- What Is The Stock Internal Limit
- Different Oem Motor Mounts?
- Headwork, Gains?
- Which Exhaust Is Better?
- Rs Short Shifter Q's
- So I Cleaned My Throttle Body. . .
- First Engine Trouble
- Need Some Help Please
- Creamy Yellow Oil?
- Recommendations On A New Clutch
- Auto To Manual Swap
- Will A 97-99 Rside Bbtb Fit An 01?
- Easy Place To Tach?
- Catch Can Getting Full Fast
- No Mas Tiburon
- Clutch Replacement
- Think Clutch Is Going Bad
- Possible Bad Clutch?
- Drivers Side Axle...
- Fans Near The Turbo.
- Lucas Oil....
- Tranny Died =/
- Engine Mounts (rubber).
- Transmission Almost Winding?
- Help With Flywheel Crank Pilot Size
- Need New Spark Plugs, Worth Upgrading?
- Lucas Oil Treatment.
- This Part Is Squeaking In My Transmission.
- Burning Antifreeze. Need Help!
- Tranny Leaking?
- My Transmisson
- Koyo Performance Rad Fitment
- White Smoke And High Idle
- Rotary Engine In Tibby
- Installing Airram/spacers...
- Gt-headers
- Crank Thrust Bearing
- Bought Another Mod Just Now.
- Weird Stalling Problem, Just Started Happening
- Engine Swap Time.
- Clutch And Oil Question.
- Question For Those Who Have Sprayed There Engine Before.
- Check Engine Light Won't Go Away.. .. ..help!
- Thats Just My Luck....
- Clutch Greasing
- Check Engine Light On
- Tranny Vent Control Valve?
- Clutch Install
- Some Newb Questions About Car Maintenance
- Cylinder Head Bolts Are Not Strech To Yield!
- Which One Do I Get?
- Digimoto Obdii Reader
- Can My Tranny Temp Sensor Cause This?
- Crank Scrapers
- Transmission Work...
- Fuel Pressure
- Help With Spark Plug Wires
- How To Fix Clutch Squeaking?
- Transmission Casualty Poll
- Bore X Stroke
- K-spec Cams
- Wire Tuck
- Clutch Install Tips/tricks
- Help! Quick! Stuck On Highway!
- Clutch Going Out?
- Huge Problem! (i Hope Not Anyways)
- Clutch Questions
- Leaking Tranny Fluid From The Axle
- Need Help!
- Ridiculous Belt Squealing
- Beta1 Vs Beta2
- Beta 1 Flywheel Bolts! What Are They And What Size?
- Hotshot 4-2-1 Header
- Estimating Repair List. Help Me Out With Opinions.
