Valve Cover Gasket Leaking?
Old Mar 9, 2006 | 02:19 PM
tanc's Avatar
Vehicle: 1997 Tiburon
What do you guys think? Since it's pretty cold here, I won't get a chance to replace it until maybe another month. I won't run into bigger problems right if I dont replace the gasket soon?
Old Mar 9, 2006 | 02:30 PM
2pacalypse's Avatar
No you won't. I used to run the car with broken head gasket for like a year and a half.
Old Mar 9, 2006 | 02:32 PM
rallyman's Avatar
That's not the head gasket, that's the head cover gasket. You'll just be leaking a little oil until you repair it.
Old Mar 9, 2006 | 02:52 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
do not worry about it! it's not head gasket! it's valve cover gasket.
You can change it later, just watch that it do not get worse and check you oil level.
I changed the title
Old Mar 9, 2006 | 03:38 PM
tanc's Avatar
Old Mar 9, 2006 | 03:46 PM
fonseca's Avatar
Could adding too much oil cause a leak at the valve cover gasket? Some fool topped my oil off to way over the full mark last time my car was serviced for something completely unrelated, and mine has leaked some too. So maybe if I remove the cover and clean everything well there won't be any more leaking, now that I am at the proper level.
It's a good thing I wasn't running synthetic, but they did add a different brand 10w30 to my 5w30.
Old Mar 9, 2006 | 04:25 PM
Mine's been spitting oil out like that for close to a year now. I'll be changing the VC gasket most likely when I swap the intake cam when I get around to it.
Old Mar 9, 2006 | 04:32 PM
Dmitry's Avatar
different oils like 10w30 and 5w30 can be mixed, especially if they are from the same manufacture.
Valve cover gasket may leak if it's not torqued properly (too low or too high).
Old Mar 9, 2006 | 06:16 PM
Mad_john's Avatar
get a new one.. just dont tighen it so tight you only need about 6 lbs of tuque on them puppys
Old Mar 9, 2006 | 07:01 PM
Rd1tib's Avatar
Mine is doing to samething, im just letting it chill till i have money to fix it and my oil pan gasket.
