PDA
View Full Version : Engine, Intake, Exhaust
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Oil Cap Is Stuck
  2. Tranny Leaking Stuff...
  3. Plug Boot Clip Broke
  4. Car Acting Wierd When Low On Fuel
  5. Timing Belt
  6. Trans Problem?
  7. Cylinder 4 Misfire Code
  8. Oil Leaking Everywhere
  9. Valve Body Wiring
  10. Radiator Vs Water Pump
  11. Ark Short Throw Shifters In Stock And On Sale!
  12. Ticking Sound
  13. Shifting... Rough
  14. Clutch Or Tranny Issues :(
  15. Idle Problems..
  16. Phenolic intake manifold gaskets
  17. There's A Hole In My Tranny, Dear Liza...
  18. Ebay Headers Bad?
  19. 60k/t-belt Questions
  20. Transmission
  21. Fuel Pump Sound/jumping Question
  22. 1.8l Flywheel...
  23. 1.6 Beta 1 Engine
  24. Car Taking A Crap On Way To Work.
  25. Throttle Body ?
  26. Crankshaft Position Scan
  27. Please Help With Clutch Choice
  28. Smog Check Rejected
  29. Ran Bad, Ran Great, Stooped Altogether...
  30. Dirt In Gas Tank
  31. Timing Belt Tension Side
  32. Broke 3rd Gear
  33. 1.8l Cam On Beta2?
  34. O2 Sensor Wiring 1997 97
  35. Info on Head Porting
  36. Engine & Intake FAQ's
  37. Power Surge From Accidental Grounding?
  38. Burning Coolant
  39. Electrical Problem?
  40. Air Water Seporator Can
  41. Help Help Please
  42. Engines Toasted... I Think...
  43. Xtd Stage 3 Clutch & Flywheel
  44. 1.8 Cam Swap Questions
  45. Trans Upgrade
  46. 2nd Gear Problem
  47. Car "lurch"
  48. This May Sound Like A Stupid Question.
  49. Help.
  50. Help Please
  51. Resonator Removal
  52. Aftermarket Im?
  53. Car Not Running Good
  54. My Second Oil Report
  55. Starting Takes Longer Than Usual Sometimes
  56. Fidanza Friction Surface
  57. Need A Clutch That Will Handle Boost
  58. Airram Vacuum Lines
  59. Beta I / Beta Ii - Exhaust Side Difference
  60. 97 Tiburon , Ingear Idle Rev Problem Please Help
  61. Fuel Injector Removal
  62. Your Opinion Please
  63. Killing Winter Blues With More Power!
  64. Short Shifter Problem
  65. Pin-outs For Siemens Map-based Ecu
  66. Car Bogging Out Because Of A Fuel Filter Change?
  67. Tranny Problems?
  68. Radiator Hose Id? (inner Diameter)
  69. Catch Can
  70. New Dentist Job In My Transmission
  71. Clutchnet....round 2!
  72. Final Thoughts On Clutch Replacement
  73. Engine Questions
  74. Our Alternator?
  75. So This Is What I've Been Up To This Weeknd
  76. Manual Transmission Fluid Change? Need Help
  77. Random Stalling And Whatnot
  78. Low Coolent
  79. Engine And Trans Swap Candidates?
  80. Act Part Number, Anyone Have One?
  81. Stupid Question
  82. Although I Feel Really Dumb...
  83. Wtb Item To Bypass Govenor/rev Limitor
  84. Clutch Diy
  85. Sharkeys Sick:(
  86. Problems
  87. Getting Ready...
  88. Clutch Going Out...
  89. Rad Hose
  90. Best Place To Get O2 Sensor
  91. Xg Strut Brackets
  92. Kjb Delrin Shifter Bushings Installation ?
  93. Trans Swap Questions
  94. 1.6l Cam Swap Instead Of 1.8lcam In A 2.0l Engine
  95. Centerforce Clutch
  96. Tranny Help!
  97. Pulse Plugs
  98. Wire Loom
  99. Cheap Port And Polish
  100. Can't Shift.. Help! - Fixed! 01.16.08
  101. Cheap Headers On Ebay
  102. Complete Loss Of Power ?!?!
  103. This One Has Me Stumped...
  104. What Is Best/easiest To Install Fpr
  105. Idle Drop, Idle Low.
  106. Underdrive Crank Pulley
  107. "name That Part" (evap Purge Solenoid Valve)
  108. Beta Ii Alternator
  109. Bogged Down
  110. Closed Loop Sluggish
  111. Clutch/throwout Bearing Question
  112. Rd1 Engine Damper?
  113. Hey Madjon!
  114. Cheep Engines
  115. Engine Stutter
  116. P0449 Code Help
  117. My Car Is Goin Turbo!
  118. Help! My Clutch Is Trying To Quit On Me
  119. Someone Help Im A Little Worried
  120. Ever Try Leather Wipes
  121. Ebay Clutch
  122. Clutch Burning Smell
  123. Idle And Stutter Problem
  124. Rpw Camshaft Blowout
  125. Tranny Problem After Clutch Install
  126. Just A Quick Question
  127. Please Help Do I Need A New Engine?
  128. Ecu Diagrams
  129. Intake/exhaust Camshaft Pair, 264 Degree Duration
  130. Oil Pan Removal?
  131. Timing Belt Change Thoughts/experinces
  132. Wierd Problems
  133. Valve Cover Gasket
  134. Clutch Change Question
  135. Ecu Pin Out
  136. Having Troubles
  137. Bad Results
  138. Trouble Finding Coolant Leakage.
  139. Windo-weld
  140. Upgraded Water Pump
  141. An Opportunity May Have Presented Itself...
  142. Automatic Tranny And Steering Problems? Help!
  143. Trouble Getting It Out Of Park!
  144. P0441
  145. Southbend Clutch Slipping?!?!
  146. What Is This?
  147. New Clutch!
  148. Ecu Question
  149. Beta Ii Pan On Beta I
  150. Is It Possible To Get A Brand New Rd1 Engine And Tranny?
  151. Engine After Seafoam And O2 Sensor
  152. Act Street Clutch - Slipping?!?!?!
  153. Performance Difference
  154. Needing Advice
  155. Need Help Id`ing My Tranny
  156. Grinding During Clutch Engage
  157. F**k I Think I Blown My Head Gasket!
  158. M/t - Resistance Going Into 1st
  159. 2.0 Motor & Trans Swap
  160. Checking Injectors
  161. Lsd's What Is Needed
  162. Tib Won't Start
  163. Need Advice...
  164. 1.8 Or 2.0?
  165. No 1st Gear!
  166. Nobody Knows Whats Wrong Help
  167. Beta Ii Oil Pan
  168. Beta Ii Trans Swap. Help!
  169. Stupid Throwout Bearing!
  170. Is It Worth It?
  171. Crank Pulley
  172. A/c Locked Up
  173. X3 Passenger Mount For Beta Swap?
  174. Check Engine Light - Codes
  175. Frankenbetaii!?!?!
  176. Os Giken Twin Plate Clutch
  177. Idle Problem
  178. Standalones?what Are You Using?
  179. My Engine
  180. Clutch Problem
  181. High Lift Cam And Engine Oil?
  182. Bad Mileage
  183. Clutch Problem
  184. 1.8 Motor With 2.0 Trans?
  185. Idle Bog. Help Me Quickly.
  186. Engine Always Misfires When I Leave It Off For A Week Or More
  187. Clutch Or Tranny?
  188. Clutchnet Clutches
  189. Building Turbo-tib Motor
  190. Alternator Bracket
  191. Idle Shaking Problem
  192. Big Problem
  193. 2000 Tibby Auto Lights/airbag/60k
  194. Did I Just Mess Up Majorly? Beta 2 Injectors Fitting A Beta 1?
  195. Heater On, Ignition Fuse Blows
  196. Beta 2 Oil Pan
  197. Stock Clutch Limits?
  198. I Need Help With Cold Air Intake.
  199. Transmission Blew Up
  200. Optimoprimes Beta2 Tranny Swap Thread
  201. Engine Overheating
  202. Alternator?
  203. Has Anyone Thought About Engine Swap?
  204. Engine Bay Fans?
  205. Clutch Confusion/opinion
  206. 4 Grand Idle.. Help :(
  207. Outter Cv Joint
  208. Check Engine Light
  209. Dead Speedometer
  210. '99 Tiburon Oil Report (145,000 Miles)
  211. Phenolic Intake Spacer
  212. Cylinder Walls Problem
  213. Header Opinion
  214. Which Engine Mounts
  215. **help! E-brake Light Stays On!**
  216. Needle Bearings...
  217. My Clutch Go Byebye
  218. Is Something Wrong..?
  219. 1st Gear Problem
  220. Help With Obd-2 Reader
  221. Installed Ss Clutch Line
  222. Quick Question
  223. Oil Cooler
  224. No Speed Gauge And Odometer.
  225. Clutch Master Cylinder Problem
  226. Smt-7? Anyone
  227. Act Clutch Disc Problem
  228. Strange Idle
  229. Trying To Help Purple Nurple
  230. Release Bearing Question
  231. Over Heating Transmission
  232. Just Got My Lightweight Flywheel, Need Some Help
  233. Timing Issues?
  234. 2000 Elantra (timing Questions)
  235. Fuel Pressure Regulator Going?
  236. Clutch Went P00f!
  237. White Smoke From Where You Pour Oil In
  238. Beta 2 Return Spring
  239. Obx Cam Sprocket Problems...
  240. Ford Tps Wiring....
  241. Which Cam Is Best For Me?
  242. Another Engine/tranny Swap
  243. Bolt Going Through Exhaust Gasket?
  244. Tranny Leak?!
  245. Help!? Rattling Engine And Rolling Idle...
  246. Engine Hissing... Help?
  247. Performance Chips
  248. A Really Weird Problem
  249. Replacing Thermostat
  250. Transmission Stuck Going On
