Idle Shaking Problem
Old Aug 26, 2007 | 09:53 AM
FMtuscani's Avatar
when im usually stopped, or in first about to go my car has a somewhat bad shaking problem, it wasnt a big deal at first but its been getting worse, anyone know what that might be.
Old Aug 26, 2007 | 10:07 AM
frozen's Avatar
Vehicle: 2001 Tiburon
Your idle is probably set too low. See webtech.
Old Aug 26, 2007 | 10:13 AM
FMtuscani's Avatar
friend said it could be motor mounts. is that possible?
Old Aug 26, 2007 | 12:38 PM
My shaking went away when I changed my flywheel. There's alot of things that can be going on, fouled spark plugs, clogged PCV, plug wires... Open your operators manual and perform the required maintenance items which correspond to your current milage versus the last time you performed maintenance. Our cars don't go to hell easily if you perform correct maintenance.
Old Aug 26, 2007 | 01:14 PM
Nex's Avatar
Nex
It could be the mounts, but the thing is that the car would feel like it rumbles not shake, especially when you're dead stopped. If its when you begin to release your clutch to engage, then its either your clutch that is worn out(i had this prob) or flywheel. Worst case its both.
I suggest you get it checked out, and dont allow yourself to get ripped off either, have a few different places check it out.
Old Aug 27, 2007 | 07:52 AM
FMtuscani's Avatar
its not really when im starting to go, more of just sitting there, i might get polyurathane motor mounts anyway, mine do look a bit bad.
Old Aug 28, 2007 | 03:03 PM
tdonnell's Avatar
OMG your sig is friggin awesome!!! LOL!
Anyway, if you let the car idle, pop the hood, and rev the engine using the pulley on the throttle body, the engine should only kick back a 1/2" to 1" max. If it looks too sloppy, then motor mounts are in order, and polyurethane ones would be great!
Just keep in mind that some slight vibration could be transferred into the passenger compartment with the new mounts due to their stiffness transferring the engine movement into the body of the car, mostly at idle. It will feel like a slight hum, very fast repetition.
Old Aug 29, 2007 | 07:20 AM
FMtuscani's Avatar
should i trust ebay, or seoulful for motor mounts i know ebay is cheaper and what not. i really dont know
