Engine Questions
Old Jan 6, 2008 | 11:22 PM
phrozen's Avatar
i smashed up my car its a 2001 tiburon se and i was wondering if the water pump and the alternator bracket/oilfilter housing and radiator from a 96 elantra would fit its a 1.8l beta
ive been trying to find the exact difference but i could find it any where just difference between beta 1 and beta 2
Old Jan 6, 2008 | 11:28 PM
if its a beta block it will fit if not it wont. there is a sticky in this forum about diffrences 3 inchs below the button you used to make this post man, you gotta search because the info is there.
Old Jan 6, 2008 | 11:34 PM
phrozen's Avatar
im sure its a beta so it will work thank i still dont see this post
i must be retarded
Old Jan 8, 2008 | 02:26 PM
phrozen's Avatar
ok so i got all that parts and yes hyundia said they are the same too except for the waterpump does it matter if i use the 96 elantra 1.8l water pump or do i need to go buy the specified one?
Old Jan 11, 2008 | 03:34 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
I think you would have to buy a water pump for a 2.0L because that is what you have correct?
Old Jan 11, 2008 | 03:38 PM
yea the 2.0 water pump will be needed.
Old Jan 11, 2008 | 10:19 PM
phrozen's Avatar
thanks guy about the water pump info now on a different topic about my engine the passenger side drive shaft is about 3/4 inch out of the tranny i was wondering if the is some clip or something in the tranny from holding it out because i can force it back in my moving the motor over any ideas would be great
Old Jan 11, 2008 | 10:27 PM
Old Jan 11, 2008 | 11:03 PM
AGreen's Avatar
What's the extent of the damage?!!! If it popped your axle out, you've probably got some serious suspension or frame bendage there bro!
Old Jan 11, 2008 | 11:43 PM
Guess I'll be the asshole today.
Phrozen. This thread is closed, and all others made by you will be closed, until you read the site rules and PM me that you have read them and understand them and will follow them.
Don't PM me about it until you've done so.
Punctuation is a b****, explanation is a b****, and searching, although EXTREMELY DIFFICULT TO DO, is mandatory here before you post. If you can't find anything, change your searching, or learn how to SPELL.
HYUNDAI.
If you can't spell that correctly yet, you are probably misspelling everything else you put in the search block.
