- Clutch Replacement
- Off-idle Stumble
- Won't Turnover When Cold.
- Need Some Help With Transmition
- 2.ol Questions
- Fail
- Crower's Summary Of Cam Profiles
- Clutch Carnage
- Cylinder Head Cover Leak
- Ever Wondered What Inside Evaporation Canister Looks Like?
- Slipping Od
- I need some exhaust!!!
- Xtd Stage 3 Clutch Kit
- I Found Out Why My Transaxle Was Making Noise.
- Need Some Advice On Clutch
- Annoying Cel, P0133, Help Needed
- Transmission Parts Blowup
- Smoke Vacuum Leak Test
- Question About Intake Manifolds
- Flywheel & Pressure Plate Torque Specifications?
- Help Me Find A Better 5th Gear
- My Oil Catch Can Setup
- Shifter Linkage Bushing: Long Term Reviews Here (please)
- Rd1 Trans Into Rd2
- Xtd Flywheel
- Evap Canister Removal?
- Gear Ratios
- Xtr Clutch?
- Manual Transaxle Input Shaft Grease
- Camshaft Trouble - Firing Order, Catcams & 1.8 Intake...
- Oxygen Sensor Wiring
- Evo Trans?
- Standard To Auto Swap
- 1.8l Cam Installed
- Help! I Took My Throttle Body Apart!
- Valve Question - Hla's?
- throttle body swap.
- Handbrake Light
- Damn Electrical
- Beta Ii Tranny Swap
- Clutch Help! Dxd Stage 5
- Solid Engine Mounts.
- Flywheel Suggestions?
- Removing Cam Sprockets
- Idle Tracking Switch
- Exedy/daikin Or Gripforce/valeo In A Couple Days
- Transmission Swap Question
- Another Performance Chip? What do you think
- Evo8 Radiator
- Trans Question
- Weight Differences - Vhr Racing Clutch.
- Oil For Cars With 75,000 Miles
- Bad Clutch/ Slave Cylinder
- Engine Damper And Solid Mount
- High Rpm
- Nasty Headers - Wrap or Paint?
- Some Very Nice Looking Belts
- Short Shifter Question
- Fiberglass header wrap.
- Full Rebuild While I'm In There?
- Timing Belt Kits
- Cleaning up the head. . .
- 4g63 Engine Swap?
- Radiator Manual/auto
- Motoria Intake Manifold
- Reference For Cylinder Head Work
- Need Some Clutch/tranny Troubleshooters In Here
- Clutch/tranny Issue
- Which cat should I get???
- Tranny Trouble
- OBX headers
- Exhaust question...
- Need Help From Someone With Motor Out
- Burning Oil?
- Fuel Problem
- Engine Mount Bolt Specs
- At To Mt
- Ye Or Ne:how To Raise The Rev Limiter.
- Transmission Rebuild(1.6)
- Beta 2 Tranny
- 1.8 Transmission Identification
- Transmission Swappers: Battery Charging Wiring Fix?
- Help! Steering Wheel Vibration.
- Engine Swap (with Pics) (vids)
- Cel Came Back On...
- Tranny Or No Tranny?
- Eom Resource?
- I Put My 1.8l Cam In Last Night...
- Click Here Need Help! Trans Swap
- Prd Out Of Stock?
- Free Mod For Autos
- Wierd Sound From Airram
- Overheating For No Reason?
- Stalling When Shifting Down / Stopping
- Anyone Know Anything About This Particular Cel Code?
- P0422
- Stalling, Worse Gas Milage, Less Hp Wtf Is Going On
- Dumb Question - Quick Answer
- Check Engine Light Has Been On...
- Igniton Lock Switch?
- Temp...?
- Junkyard 1.8l Cam
- My Head Has Holes In It. They Need A Port And Polish!
- Transmission Leakage
- Reverse Light Sensor.
- Passenger Cv Shaft Joint Stuck Partially In Transmission
- Basic Engine Swap?
- Oxygen Sensor Front Or Rear?
- My Engine Before Accident In My Silver Tib
- Cel!
- My Beta 2 Swap... In Progress
- Beta 2 Trans Problems
- Exhaust Rebuild Options.
- Follow Along W/ My Auto To Manual Swap!
- Valves And Their Holes
- Harmonic Balancer Issue?
- Engine Swap
- Catalytic Converters
- Tranny Removal Problems Help!
- Why 2.0 And Not The 1.8
- Timing Belt Changes
- Bad Motor Mounts? Help Please
- Idling Issues, Had It Scaned.
- Noncvvt Swap To Cvvt Engine?
- New Clutch Problems Please Help
- I Blew My Engine
- Random: Do You Still Have Head Cutaway Photos?
- Problems With Car Cutting Out
- Car Idling Weird
- Sub-par Gas Mileage.
- More Clutch Problems
- 1.8l Pistons . . . Higher Octane Gas Required?
- Apex-i N1 exhaust notes?
- New Clutch Question
- Random Noise And Scariness
- What Flywheel Should I Buy
- Tranny Issue
- Finishing My N/a Setup
- Pulse Generator?
- Leaky Head Gasket =[
- Best Bang For A Automatic?
- Stupid Is As Stupid Does
- Clutch-which One To Buy
- Changing Transaxle Fluid (manual Tranny)
- Idle Problem. Revs Go Up And Down
- Car Dying Periodically
- Blew My Clutch
- Flywheel Question
- Clutch Issue
- Volo Vp11 Preformance Chip
- O2 Simulator
- What Fluid To Use For Slave Cylinder Hydrolics..
- Gk Trans On Betta 1 Engine?
- How Do You Put On A Radiator Support?
- Cel And 94 Octane. Could They Be Related
- Stock Injectors Sizing
- Another Beta2 Engine Swap...
- Pistons/rods
- 2000 Tiburon Broken Timing Belt
- Slipping Clutch Or Bad Belts?
- Few Questions
- Got My New Tranny.. Now Some Questions.
- 2nd Gear Grinding...
- Discoloration Headers
- Approaching 30k Miles
- Clutch N Tranny
- Clank Click Clack
- Head Gasket Woes?
- Custom Carbon Fiber Fuse Box Cover
- Pulled Her This Morning
- Auto Trans Questions
- Will A Beta 2 Head Bolt Up To Beta 1 Block?
- 6-speed Help!
- How To Do A Beta Wire Tuck
- Intake wrap
- Troubles With My Engine
- Poly Motor Mounts?
- Complete Ecu Wiring Diagrams
- Car Kept Turning Over But Not Starting
- Problem Tiburon On Lpg
- Fuel Pump Bad?
- Upgraded Engine Mounts?
- Differential Used In Our Transmission
- Clutches
- Half-shaft Replacement
- P0131 And P0135 Still Persist!
- Cam Specs?
- Greddy E-manage?
- Trying To Hardwire My Shift Knob Lights
- E3 Spark Plugs
- My New Header
- Pissed.......
- resonator removal
- Megan Racing Header! (equal Length)
- Posible Tranny Issues
- Possible Intake Leak?
- Verify
- Performance Questions
- Transmissions Parts
- Cel Light Check Causes Window To Go Down
- Need Help With Tb And Cam
- Cel: P1128
- Possible Flooding Problem?
- O2 Sensor Extension
- Elantras And Tiburons
- Dual Catbackexhaust For Rd2?
- Quick Engine Question
- Emissions Problem
- How Much Power Does A Preformance Camshaft Add?
- New Exhaust Roadblock
- What The Hell Is Going On!
- I Changed My A/c Lines, Should I Refill Myself, Or Take It In?
- Installing Cruise On A Bbtb
- Tib Is Over Heating!
- Replacement Synchronizers
- Time For A New Clutch Or New Fluid?
- Trany Swap, Auto To Auto?
- Exhaust Compatibility
- Rotating The Engine?
- Hydraulic Lash Adjusters
- Major Problem.
- Motor Mount Bolt Size Help
- New Clutch Install Problems
- Need To Buy New Clutch
- Air Water Separator For Catch Can
- Cel Question
- Megasquirt Software Questions...
- Anyone Drive W/o Belt Covers?
- Oil Pan Gasket Questions
- Measuring Shaft End-play
- Vacuum Line Diagram
- Rad Drain
- Alternator Stuffed
- Quick Clutch Question
- Coolant Temp Sensor
- Need Help Finding The Pulse Generator On A 2001 Tib
- Acel Sensor Effect Shifting On A/t
- Clutchmaster Clutch?
- Stiff Clutch Pedal From Racing Clutch
- Matrix Oil?
- No Low End Power, And O/d Does Not Work Even With The Light On
- Does Anyone Know Wether This Will Work
- Stuck On Fuel Pump Removal (help)
- Intake Manifold Gasket Change
- Engine Piece Question
- Clutch Suggestions?
- Stronger 5th Gear Madjohn
- Oil Cap Is Stuck
- Tranny Leaking Stuff...
