A Really Weird Problem
Old Jul 5, 2007 | 03:55 PM
99FX's Avatar
lately i've been having a wierd problem where my engine doesn't run as good as it should... i will start up and run it but once i shift into 2nd and put the accel back on it just revs and doesn't go unless i let go of the gas the slowly put it on..(((not just 2nd gear sometimes 3rd and 4th too))) or sometimes when i am about to go from a stop the gas will make my engine stall out??? like i put the gas on and the rpm's drop real low... i dont know if it is the whole clutch or if it is small smaller minor prblem
Old Jul 5, 2007 | 04:25 PM
Tokin's Avatar
Vehicle: 2001 Tiburon
So when you shift into whatever gear and hit the gas, the tach moves but not the speedo? Sounds like your clutch is slipping. Might be time to replace it.
As far as the stalling I don't know if that's related to the clutch, but the other issue seems cut and dry.
Old Jul 7, 2007 | 05:05 AM
99FX's Avatar
weell that sux.. i was hopeing it wasnt the clutch.. o well thanks though
Old Jul 7, 2007 | 07:48 AM
how long has it been since your spark plugs were replaced?
Old Jul 7, 2007 | 09:07 AM
yep... change your clutch... It's not that hard. I did that 3 times in 2 months because my buddy helping me kept improperly installing things. It's really not hard if you review the DIY guide about 3 times before you DIY. You've just got to have about 10-14 hours of time and a friend to help you with the bell housing.
Old Jul 7, 2007 | 11:16 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
there could be 2 possible problems:
1) clutch
2) loosen mufler belt
Old Jul 7, 2007 | 12:15 PM
^^ dang.... I forgot about that. Yeah, check muffler belt tension!
Old Jul 7, 2007 | 04:33 PM
99FX's Avatar
thats wat i thought a butt load of beautiful time just me and the tib.. looks like i'm playing doctor again..lol i was thinkning putting in a stage 2 or 3 clutch masters??? but i keep hearing good things about ACT?? and i'm not sure when the sparks got changed?
Old Jul 18, 2007 | 07:43 PM
AGreen's Avatar
Sorry to post on an older topic, but just throwing a clutch at it doesn't sound like the sure fix for this problem.
Here, he said that the rpm's go waay up and the car does nothing, which sounds like a clutch-slipping issue.
QUOTE (99FX @ Jul 5 2007, 05:55 PM)
But then he said this...
Sounds like the same problem I had when the tps went bad, which is apparently a pretty common problem with the DaeSung tps model. My symptom was when I stomped the gas, the rpm's dropped down very low, and sometimes it would cut the engine completely off.
Just something extra to think about before ripping the transmission off...
Old Jul 18, 2007 | 08:15 PM
demon_fox's Avatar
Vehicle: 2000 hyundai tiburon
good point ^
