- a few exhaust questions
- Pistons pics
- fuel questions
- Calling Chuek.
- Where to buy silicone connector for CAI?
- Cleaning Headers
- How much oil ?
- red said....
- Engine Ticking
- O2 sensor question, of a different sort
- High Flow CAT!
- The day is NEAR!!!
- O2 Sensor Question?
- headers or throttle body?
- K&N air filter
- RS cai
- Tornado Performance Booster
- 20 HP for $10...WTF!?!?!?
- ECU wiring diagram
- Good S-AFC settings
- Weapon*R Intake & Cold Airbox.
- throttle body question?
- NEED CAI TO FIT
- K&N Filter Recharge Kit
- Cool Cans
- us spec headers.....
- Heat shield on Fuel filter????
- list....
- bbtb group buy
- 550cc Lucas injectors for sale
- Header Install on Friday!
- What Kinda...
- Anyone here about the New Exhaust
- Pictures of the Hyundai Project (56K users beware!)
- Onpol IM
- How Fuel Trim works (how your ECU learns to adapt to your mods)
- Filter Fiasco!
- Thoughts on this...?
- boring a throttle body
- Sharkracing Engine Hose Sleeve Kit
- dual exhaust
- SR's CAI..?
- S-AFC wiring diagram / hints or experience
- RED !!!! Check your PM.
- mbrp exhaust
- Fuel booster....???
- Custom cai finished..
- Red, maybe you will respond here......
- air filter
- Project update for Saturday/Sunday...
- HVE Exhaust good?
- header question?
- 2nd Gear Crunching!!!!
- Carburated?
- SHORT RAM INTAKE
- carb aproved
- Breather Filters
- ENGINE MODS
- 2.5'' Custom Catback Finished!!!
- cam/ECU offer
- Have you been to CAPA l8tly?
- results of first mod
- Just making sure before i buy
- Converting kW to Hp
- Ok what else do i need for my power upgrade
- Time To get cams
- custom exhaust question?
- Engine failure..........
- Project update for Thursday night...
- intake problem
- EVERYONE CHECK YOUR PM'S!!!!
- OBX mufflers
- V-6 OR THE I-4
- MAF to MAP Red, Random anyone
- 2.25 OR 2.5!?!?!?!?
- Hyper Intake vs. Dragon Intake
- 2k3 exhaust ?
- Twin throttle body
- Oppinions on Exhaust
- resetting ecu
- Larger MAFS?
- Project Update - Tuesday night
- Timing advance kit on ebay
- unorthodox vs aos pulley?
- SR SplitFire or Magecor KV85
- Engine coolant level
- engine: time to switch sinthetic, flush engine?
- wtf is the random special?
- i also have a TB question...
- Cai Questions
- HRD, question
- timing adjustment modification
- Project update...
- Throttle Bodies
- Timing advance kit on ebay?
- Hi-Flo, but quiet exhaust search
- Hole in shortblock
- Does this really work???
- Hey fordfaster
- Just finniished my new CAI
- MAF Question
- TB Question here
- SR-GT Cam
- My New CAI!!!
- ALERT!!!!!!!!!!
- Header install?????
- Attn: Random and Red -- Oil return line
- Ebay timing advance kit (caveat emptor)
- Sparkco 9.2mm Ignition Wires... how are they?
- ODBii Cable Group buy.
- As promised, more pictures of Haltech E6K (56k users beware!)
- Which model number!
- 1st Gen. Diaper Change
- Intake Manifold Update
- Muffler's glasspack vibrating... does it happen to yours?
- o2 sensor wire extension
- Magnaflow, DynoMax, 3A Racing and more mufflers... What's the difference?
- Red, check this out !
- Hold
- what muffler???
- porting and polishing IM
- perforated core glass pack
- MAP Replacing MAF
- Catalytic Converter Question.
- Throttle Body
- Boost Controller and BOV question
- Exhaust Sound Clips
- 4-2-1 headers dyno?
- S-AFC / Fuel Pressure Regulators / etc
- Korean Sites
- T-minus 6 days, 18 hours, 52 minutes and counting...
- 4-1Headers/ Speedstate / Highflow cat/ OH MY!
- ? about barney throttle body
- Increase wheel hp?
- Intercooler question
- How much HP loss?
- Apexi S-AFC
- Extrude Honig
- Transmission drain.
- 421 header ?
- Timing belt check
- Not sure if I understand ignition timing
- Header wrap etc.....
- Fastest NA 2.0L
- 4-1 Headers
- Carsound cat?
- barney bbtb
- Phase 3 chip?
- Relocating O2 sensor without cat?
- CNC Fuel Rail, Phenolic Intake Spacer, LIght Pulleys
- HKS Hiper Titanium Race Muffler!!!!!!
- Valve springs...
- 2.0L block
- Couple of questions....
- normal or synthetic oil
- new design question for BBTB
- Header
- Group Buy For BBTB...LQQK Here
- Shark Racing Intake almost finished!
- CAI and MAF Sensor housing
- S-AFC
- Cats
- ? about header
- Blitz Cone Filters for CAI's
- New lantra cam and vacuum
- CAI Pics PLease
- CAI w/ Automatic Tran Question
- removing one cat
- 35 p.s.i.
- will it pass emission?
- Can I cut this
- HVe Carbon Fiber Intake
- aos cai
- HDK ECU......
- SR 4-2-1 headers whith MBRP cat-back?
- cam shaft effects.....?
- Battery relocation...
- I've been a little quiet, but the project draws nearer...
- fuel pump issue.. plug fouling ...
- Throttle Response ?
- CAM Gears
- TeamSr or Injen Intake?
- Easy air to your intake/engine cooling
- replacing tps
- quad throttle bodies
- Buyign a used muffler
- CAI vs. rain
- Spark Plugs and Wires
- catback exhausts
- which do u think has the possibilty of being faster?
- Co2 on the intake
- I want 2 run 12's
- muscle car sound?
- More Speed
- powder coating
- Idle Question
- Question for anyone
- Fuel Economy Question.....
- Paint that Insulates
- Throtle bodies
- To much Torque
- Random, someone check this out p[lease.
- Yam, Ram, or big o SAM
- Header Workings....
- Throttle Bodies
- twin canister muffler ??
- Thanks Random!
- Installing 4-1 headers
- to cheuk, red, random, or anybody else
- Injen CAI...possible group buy...
- MAF vs. MAP
- CAI or Cone air filter
- MAF
- My first CAI
- Are you GOing
- DUAL PURGE LINES !!!
- Custom CAI Finish (finally)
- Fuel Pressure Regulator Tech Info...
- AOS Auto Intake 1st production run
- Random about he Special
- Mr Random...
- Exhaust Gasket
- today's the first tme i ever regretted having an AT...
- Suggestions needed..
- MR. RANDOM SIR
- kia sephia header question???
- Pulleys
- Performance?
- homemade CAI
- raced a civic hybrid !! I got beat badly !!
- Shark Racing Question.
- header bolt tightining
- 4-1 Headers
- question from the new guy
- How much torque can the 2k3 Take
- Hi fellowsharks
- ebay muffler?
- O2 sensor
- Stock Headers
- My own custom CAI!
- Performance diff between 4-1 2.5" and 2"
- Group Buy For Throttle Body(s)
- For a Glasspack
- OBD Datalogger Question
- Please answer ASAP
- Question About Drive Train
- Serious Exhaust Question For those who know
- Being smart...
- mhm
- Exhaust Explanation
