PDA
View Full Version : Engine, Intake, Exhaust
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25
  1. ngk vpower plugs
  2. CAI Question (Not a question about which CAI to get)
  3. Hyundai and Kia engines
  4. More Zettyness
  5. Really BBTB
  6. RS-CAI Dumb Question..
  7. obx adj. cam gears
  8. Porting
  9. throttle body cause this problem?
  10. Mantecore wires, quick
  11. Universal FPR
  12. Need advise from u grease monkies
  13. Kia engines=mazda
  14. Kia announces overstatement of horsepower ratings
  15. Someone please explain a piggy back computer.
  16. header installation question
  17. Heat wraping CAI and exhaust
  18. returnless sys pros and cons?
  19. Intakes - Which is better?
  20. Hyundai Admits HP was overstated
  21. Identifying my engine
  22. SR HEADER Q
  23. Running LEAN!!!!
  24. CAI
  25. Headers
  26. Beru Silverstone From Nology spark plugs
  27. Immobiliser Woes
  28. idel/rpm messed up
  29. ignition
  30. were to get gsx fuel pump
  31. CrAcKiNg exhaust manifold
  32. Transmission Fluids
  33. Gates belts
  34. B&M Trick Shift
  35. Best sounding and performance gain exhaust?
  36. header/exhaust
  37. engine painting
  38. crankshaft teeth
  39. FPR = cheap alternative to SAFC?
  40. stroked 1.5???
  41. which header is which header?
  42. Fast- Technology???
  43. Will this cause problems / danger with intake???
  44. Performance Question
  45. raising comp ratio?
  46. SR CAI Vs. Injen CAI?
  47. O2 sensor extension question
  48. convert 2.0 to CC's
  49. Pics. Of my Injen Intake!!!!!!
  50. Question: Collector Size and catback
  51. O2 spoof.
  52. Fuel Pressure regulator with gauge?
  53. RED AND SKEIRD
  54. CC INSERT update
  55. The Danger of Power Pulleys & Understanding the Harmonic Damper
  56. Supposed Oil Leak
  57. fuel pres reguator
  58. adjusting the idle how do u adjust
  59. car wont start!!!!!!!!1
  60. SR headers and MBRP catback; making it work?
  61. Powder Coating my IM
  62. MAPS settings for SAFC
  63. what is the manifold flange
  64. removing intake manifold
  65. Air Compressors?
  66. Aftermarket engine mounts...?
  67. How much would it cost...
  68. OMG!!!!!!!!!!!!!!!!!!!!!!!!1
  69. I think I broke my engine!!!!!!!
  70. New release from Haltech...
  71. Time to replace my ATF
  72. HVE Intake installed... (PICS)
  73. TSR Test Cars Needed
  74. You've Got To Be Kidding Me!!!
  75. Check Engine Light anyone???
  76. What to do next?? any tips??
  77. size of hole to put in intake fro direct port
  78. finally...tuning time ;) dyno and s-afc
  79. Air Filter
  80. Another crazy idea...
  81. Radiator fan... which way does it blow???
  82. Bringing NA mods into balance for max power
  83. wtf hoses on stock throttlebody?
  84. new gaskets needed?
  85. Throttle body instructions
  86. Found a few more Hyundai Products.
  87. Stock Exhaust Question
  88. Buying Pulley with a Big System
  89. 03 cams
  90. rpw cams vs gt cams
  91. onpol cost of intake job
  92. SR CAI
  93. Time'n advance kits???
  94. Breather filter and weapon*r intake
  95. Has anyone thought this???
  96. Advantages and Disadvantages!
  97. Cams???
  98. Dyno video
  99. Compression ratio!!
  100. 1st gen Euro lights
  101. PCV Oil/Tranny Catch Can Explaination
  102. HP loss from heat
  103. Quiet CAI
  104. exhaust width
  105. fuel pressure regulator
  106. Exhaust Buzz
  107. Where to go to get a cat removed?
  108. engine bay pics
  109. Could This Work!?!?!
  110. ignition systems...
  111. Opinions on Arospeed
  112. Apex'i N1
  113. Big Problems
  114. 1.5 cam
  115. Pics of my Random CAI installation
  116. Cam Swap..GONE BAD--Pix
  117. New Catback Exhaust
  118. Crappy 1/4 mile time
  119. polishing hot plate
  120. Better 1/4 times
  121. 75 shot direct port on stck fuel pump
  122. Exhaust, cams& eng light
  123. can someone suggest good engine build-up books please
  124. cause of cam, i now need to get rid of check engine light
  125. engine hose
  126. Exhaust Sound Suppression Inserts!
  127. Anyone used "Engine Restore" before?
  128. Cheuk, question on the "GT intake manifold"
  129. Going to the Exhaust Shop tonight
  130. Dyno sheets
  131. Here is a list of Hyundai's engines from their corporate site.
  132. Header diffs
  133. Cam specs
  134. Engine Noise
  135. My AOS Intake Pics
  136. I was reading someone's post...
  137. switching heads???
  138. Which is better...
  139. urgent! inline fuel pump
  140. More Headaches!!
  141. aem fits the automatic
  142. i need a new trransmission
  143. What is this, and what purpose does it serve?
  144. new s2000
  145. cherry bomb resonators glasspacks
  146. is anyone out there making real power?
  147. O2 Sensor "recalibrator"
  148. Do people have any shame anymore?
  149. My Upgraded TQ
  150. Oil
  151. Got my intake in today!!
  152. Coil low voltage pulse
  153. Difference in Headers
  154. header vs. cam
  155. Urgent!! SAFC question
  156. While it's not really useful yet...
  157. Engine Dismantlement
  158. yikes
  159. Any one dyno the AOS intake?
  160. My exhaust plans are finalized. i need opinions!!!
  161. Relation between muffler size and exhaust tone
  162. AEM Intake is Here!!! (I got Pictures!!!)
  163. Sensor Signal Modifier chip - good idea or bad?
  164. castrol syntec
  165. tuningparts.co.kr
  166. Problems with Cruise Control?
  167. Removing 2nd cat.
  168. 2k3 gt peroformance
  169. Prolong or Other Oil Additives?
  170. FEEL THE RATH OF JAWS!!!
  171. GT cam specs
  172. Question about the A'PEXi N1 muffler.
  173. Fuel enrichement
  174. How do you set the timing? Special tool?
  175. Reasonable price for a KORE cai?
  176. diff between Race headers and reg headers
  177. CAI Tube
  178. CAI / Engine Pinging
  179. Motec/Haltech regarding to FMU
  180. making a CAI
  181. new intake
  182. Where can I get my speed and RPM needles calibrated?
  183. Power Steering Question
  184. Check Engine Light flashing. Assistance Required!!!
  185. 1.8 maifold
  186. My Warranty exhaust Story by Tony Montana
  187. Performance ECU chips who makes 'em
  188. simple cheap intake!
  189. 4-2-1 Headers
  190. Air intake = performance/fuel economey/horses?
  191. Nology Hotwires
  192. Aftermarket FPR - Vortech FMU?
  193. Headers and existing exhaust.
  194. EGT's: what's a good range
  195. fuel pump kill switch
  196. low cost effective exhaughst
  197. Second time my transmision fails
  198. stop rust on exaughst
  199. Custom Exhaust for 2003GT V6
  200. Intake
  201. Busted and Disgusted...
  202. RPW Performance cams
  203. Can Anyone Recommend a Good Battery?
  204. is this worth it
  205. How much does weight effect performance??
  206. Muffler flow rates
  207. 1st weapon r intake for daewoo leganza
  208. one last question and ill leave you alone
  209. How bout this for an Intake?
  210. DAEWOO MAX INJECTOR LIMIT
  211. STOCK Eclipse fuel pump
  212. Catback!
  213. Feasibility?
  214. Alternative to Level Ten?
  215. intake
  216. OBD-2 scantool
  217. Ghetto Gaskets
  218. 13:1 pistons 2.0L
  219. EGR removal?
  220. Sparkplug gap question.
  221. BBTB w/o BIM
  222. For those looking for GASKET KITS
  223. Been racing recently - need another temp gauge?
  224. high flow cats
  225. Exhaust Question
  226. Cams
  227. A question about intakes
  228. Custom CAI on a 2001 Kia Spectra with pics
  229. average cost of getting IM bored out
  230. SR Cold Air
  231. "Like stealing candy from a baby..."
  232. Anyone seen a muffler like this?
  233. Random Special material
  234. 5 whp with the purchase of a 2L Coke bottle DYU???
  235. Can IM's four runners be bigger than the engine port and gasket openings?
  236. Side Exit Exhaust
  237. header question
  238. 2003 Dual Exhaust
  239. Alpine problem solved
  240. Exhaust, stumped :(
  241. What times have you guys run in 1/8 mile or 1/4 mile (not G-Tech)?
  242. Pulleys
  243. rattle from my cat-back exhaust
  244. hi flow cat
  245. Heat wrap
  246. Question about two throttle cables
  247. Bored throttle body
  248. Question about stock Exhaust and 1 piece headers
  249. Intake Sensor Question
  250. Size of stock exhaust
