FPR = cheap alternative to SAFC?
Old Sep 6, 2002 | 12:25 AM
JonGTR's Avatar
Default FPR = cheap alternative to SAFC?
Since our cars run mostly rich through the band, could we get a cheap FPR and DECREASE the psi a bit to run a little leaner on a near stock engine?
Old Sep 6, 2002 | 12:40 AM
DESIGN's Avatar
It might work but without dyno tuning it or an SAFC to monitor it how could you tell how much to lean it out?
Old Sep 6, 2002 | 12:44 AM
JonGTR's Avatar
Not necessarily dyno tune it, but check the o2 readings would suffice. If the stock psi is 44.3, then maybe dropping it to 41-42 would be enough to be on the safe side.
Old Sep 6, 2002 | 12:56 AM
DESIGN's Avatar
Do you have a way of checking the O2 sensor such as the obdII software and cable?
Old Sep 6, 2002 | 12:59 AM
JonGTR's Avatar
Old Sep 6, 2002 | 01:13 AM
Red's Avatar
Red
If you lower fuel pressure, it affects ALL RPM bands.
Since these cars only run rich on the top-end, by decreasing the pressure to make it OK at high RPM's would also make the car run catastrophically lean on low RPM's.
Old Sep 6, 2002 | 01:19 AM
JonGTR's Avatar
Catastrophically = kaboom?
Old Sep 6, 2002 | 03:15 AM
Josh's Avatar
Vehicle: 1997 Hyundai Tiburon FX - now 2006 Infiniti M35 Sport
If something so simple would have given performance gains, Hyundai would have already done it.
I wouldn't look for cheap hp increase, because in reality, they don't exist.
Old Sep 6, 2002 | 03:32 AM
JonGTR's Avatar
