- is all this necessary?
- clutch install
- tired
- Full Exhaust
- EMERGENCY - Need Help - Tranny Dead?
- can tiburons have motor swaps?
- New Clutch feels great
- where is my ecu?
- CAI on its way
- intake port temp testing.
- Clutch making a buzzing noise
- cleaning headers
- what's the cylinder order?
- Where to get Nology wires?
- Smelling fuel,poor acceleration and mileage
- IS it worth it>?
- Noise
- 01 auto - manual switch
- ECU Harness Removal
- Stock Crank
- my 03 tiburon
- Exhaust manifold retorque required?
- Checking spark plugs...
- Short Throw Shifters
- Silicone hoses
- Bad Gas? Spark Plug? Engine Problems!
- Looks like I will be needing a new clutch soon.
- Stalling in Reverse. SOLVED!
- I'm lazy..
- B&M Short Shifters
- i got a ? ..and i kno my tranz is already messed up
- Which Cam?
- Painted engine components
- What is this junk from my engine?!>
- Need your help
- Exhaust
- exhaust = KW?
- AEM CAI install
- Auto to manual swap
- Timming mods.
- OBX headers, a complete kit?
- letting engine warm up
- BBTB's
- my tranz!
- CAI question
- pressure plate tech question
- Kspec.com New Product: RSide Short Shifters
- Kspec.com New Product: Air Ram Intake Manifold.
- FORGED PISTONS
- headers, cai, cat-back, how much hp?
- Installed CAI, ecu problems??!
- Cam Belt Change
- How effective is cold air intake on a Tiburon FX
- K&N looking for test car for intakes!
- spark plugs
- More tranny help
- Tie rod - Tranny Removal Help
- I have no idea!!(tranny??)
- AEM CAI on Auto
- Plug Wires?
- what is this?
- Well, I FINALLY ordered some Redline fluid
- Clicking noise after hard driving (Solo driving)
- Clutch alignment tool
- power steering belt
- How many people have cracked their Exhuast manifold
- Oil Filter relocation Kit
- Autotragic Transmission Service.
- Tanabe Racing Medalion
- I'm gettin a new tranny
- CAI problems in winter?
- MBRP Catback Reviews
- How important are wires?
- Eclipse injectors
- My Dyno and Stock Dyno *Video*
- Header Heat
- Intake manifold removal and spacer
- Piggy back computer choices
- OBX 4-2-1 Headers..gasket?
- Anybody wanna free intake from K&N?
- ignition wires
- Installed Intake Manifold no got a question
- running it out the header
- Exhaust pipes
- Computer chip
- Power enterprise engine belt
- oil cooler
- 160 whp
- UK cold air intake question
- Rally CAI
- cool intake..i guess
- Do we share injectors with ANYONE?
- to measure mixture aire/fuel
- uh oh
- N/A guages
- Does anybody know where the OBX Cold Air intake filter sits?
- quench area
- Low end power
- S-AFC II on the way...
- Splitfire Triple Platinum Plug-Gapping?
- V6 Injen Intake Install
- 4-2-1 headers
- quick question(new question for you random)
- nterchangable parts...?
- V6 Exhaust shipment (current)
- is it even possible?
- which one should i!
- My new IM
- cat then flex pipe or flex pipe then cat
- Battery Question...
- ecm question
- List of Intakes
- OBX header and O2 sensors
- new flex pipe question
- catback... or header back?
- rx7 injectors
- exhaust
- Fuel Line
- Fuel pressure Regulater
- Walbro and SX Regulator Installed (tuning problem)
- VeilSide v6 exhaust
- exhaust interchangeable?
- V6 fuel milage (6spd)
- Injector / Fuel pressure reg. Question
- whats the difference
- Brainstorm or Brainfart?
- dreams of 1.8L in 2.0L block shattered.
- dynomax VS magnaflow
- Injen Intake GroupBuy
- AEM Filter Replacement Idea
- Intake
- Blue Plug Wires...
- spark plugs
- MSD Dis-2 Trouble
- Better Fuel Milage?
- Haltech installed and tuned!
- MAF "grate"
- ReSleveing the Block ???
- New plugs and wires
- Just got back
- MBRP rear pipe/muffler on stock exhaust pipe SOUND
- Dumbass Newbie Questions (Engine)
- AEM CAI
- Using a fuel injector for water injection
- Notes on the XD cam from Professor Ko
- New exhaust for the summer!
- Cheap CAI
- Gen 1 & Gen 2 Heads
- KORE cai
- INTERNAL DAMAGE PIX
- best air filter shape?
- ingntion coil
- EVAP purge valve operation
- Injen CAI on automatic?
- exhaust leak = full new exhaust
- SONIC TESTING???
- Information about Head porting.
- MSD 2-Dis programmable Ignition System
- Grounding Kits = more power????
- Cool Flex Radiator Hoses
- eclipse 450cc injectors
- Quick quetions about SAFC
- what are good head bolts
- plasma booster???
- Will this hurt my engine?
- Another CAT Question
- Heat Refective tape on CAI?
- AEM CAI in automatic
- spark plug wire????
- What's your estimate for this mods? (Random?)
- obx headers
- autronic standalones
- Stock muffler....with mods
- newbie cai question
- SR High Cams - Tuning Questions
- Stock Exhaust restrictions...
- exhaust cut-out
- S-AFC Correction map plotter
- question
- 77.5mm to 85mm bore
- KORE intake
- KORE Catback Exhaust
- Guage wire O2 sensor extension
- Catalytic Converter -- Inquring minds want to know
- Cats
- Engine dress up and THE warrenty
- Hla Questions
- good BIM/Polish cost?
- Aftermarket Crank ????Where
- just a little hla info
- The use of ceramic coating
- Replacing rings
- which would be better for my car
- 2.5 inch stainless exhaust flanges
- Raising the good old redline
- Intake & Exhaust Flow FAQ
- 3" filter on 2.5" pipe
- Q-Tec
- Muffler
- HP Racing air filter
- 2.25" header back exhaust...
- CNK Ceramic Headers Group Buy.
- Melted my cat!
- hello check out my dyno V-6
- Intake travel Question?
- I NEED OPINOINS ALOT OF THEM
- Please need opinion onArospeed Headers
- Will stock valvetrain work with...?
- need coments on this muffler
- head porting info... ?
- Pent Roof vs Semi-Pent Roof
- Crank Pulley removal
- Coupla Q's
- $100 2.0L project motor.
- How to modify stock Throttle Body..
- Cat/Resonator?
- 4-1 vs 4-2-1 headers
- Flex-a-Lite fans
- Read your Plugs!!!
- Plug wires
- intake sensor mod
- ngk wire sets
- Stupid Idea...
- emission testing with 4-1 headers with cat
- throttle body
- HEADERS QUESTION!
- I need expert advice
- bypass valve
- Jacobs Electronics...
- resonator
- valve retainner
- hayden oil cooler???
- A pully kit from OBX?
- Stupid cam question..
- Keymotorsports ECU reflash?
- Dual Chamber CAI????
- Shark Racing Ultra Lightweight Crank Pulley
- Gear Oil? Nut size?
- Engine Grounding - Random, Red,...etc, your thoughts?
- 4-2-1 Header fittiment question
- which oil...
- wanted: kore catback picture
- Tornado????
- Another CAI question
- New CAI
- AEM CAI...
- Spiraflo Units
- 2nd cat...
- IM Question... QUICK PLEASE!!!
