I'm lazy..
Old Nov 20, 2003 | 03:22 PM
Sznurek's Avatar
I installed my aem cold air intake last weekend but I didn't put the shield that you are suppose to trim back on. I didn't feel like trimming it. Does it make a big difference? Should I trim and put it back on? Thanks.
P.S. It sounds awesome. I love it!!!!!!!!!!
Old Nov 20, 2003 | 04:36 PM
javageek's Avatar
I think you will end up with alot of debris in there. You may end up getting more water/dirt on your filter than normal.
Old Nov 20, 2003 | 05:31 PM
Thortib's Avatar
I live in Seattle and I know that if I had left that piece off my engine would be destroyed by now. If you live anywhere it rains I'd suggest cutting it. It really wasn't even that hard for me to cut. I just used a steak knife I had at my house and my friend held it while I cut. The plastic cut surprisingly easily. So I think that it would be foolish to not take the five minutes to cut it because it could end up messing with your engine.
Old Nov 20, 2003 | 08:37 PM
canadianshark74's Avatar
I also recommend putting it back in, also to second what Java said, your filter would get messed up in a big hurry.
the AEM does sound awesome, eh smile.gif I love my aem intake, everything except the price.
Old Nov 21, 2003 | 09:03 PM
pare_john's Avatar
put it back on to limit the amount of debree that will come into contact with the filter
Old Nov 21, 2003 | 11:59 PM
Sznurek's Avatar
Default Applying Decals
The filter looks like it protected by the other shield (one by the fender). The shield I have off is the one covering the bottom of the engine and stuff..
Old Nov 22, 2003 | 01:30 AM
Thortib's Avatar
It still helps to protect your filter. There is really no reason to not putting it back on.
Old Nov 22, 2003 | 09:38 AM
that one helps keep your engine compartment clean.. and it might help with cooling.
Old Nov 22, 2003 | 10:47 AM
shostlye's Avatar
Default stock gages for RD1
well i did not put it back on and i change my filter every 6 months.. now you know having a dirty filter= cleaner air into the engine but it also does= less air soo ... you will have to be the judge.. and i live in south east pa soo i do experence some harsh weather...
Old Nov 22, 2003 | 04:24 PM
KayJai's Avatar
QUOTE (supermanshark)
now you know having a dirty filter= cleaner air into the engine...
Dude, think about this for a sec.
A dirtier filter will mean you have more of a chance of getting smaller pieces of crap into the engine, when it's sucking air and you're reving at like 6k's
PUT THE PIECE BACK PEOPLE.
MAKE THE HOLE, DON'T BE LAZY.
If you want some more air to go to your filter. cut a little slit at the bottom of the fender liner and hold it open with some tie straps.
Probably cut a slit about 1"X5" at the front of this piece:
Then when you need to close it back up (ie winter) just use the zip ties to do it, or duct tape
