oil cooler
Right i am about to finish my oil cooler install and i have a question.
For those in the know, i currently have an oil temp sensor located in the sump drain plug. But due to the fact that it is brass it gets a little more damaged every time i change the oil. So i want to move it.
I have bought a T-piece for the purpose of braking into the oil cooler piping. My question is where should i locate the sensor. My guess is on the side that feeds the oil cooler( from the outer ring of holes on the oil filter correct???) not in the return pipe(center hole??). Also i know the temp will be higher than in the sump but this will only be fractional wont it???
TIA Jon
TIA Jon
jon-
You can buy a spare oil pan (new or used) and have a machine shop weld on a threaded bung for your temp sensor.
You could also 'T' off the stock oil pressure sender, or tap the head for the oil temp
I'm going to remove my oil pan this weekend and bang out a dent (still don't know how it got there), clean out the sludge, and drill a hole for my turbo drain line.
That, and I think I'm leaking a tiny bit of oil out of the pan seal while the car's running.
The procedure isn't hard, just time consuming. There are a lot of bolts, but once you have it off, you can weld, drill, epoxy, thread anything you want.
Hopefully I'll get some pics and have an idea of the PITA factor next week.
good luck,
AC
good luck,
AC
