- ram air
- MHP Intake
- removing a/c and p/s
- Hey Decker
- aos intake?
- exhaust
- header/exhust ?
- korean spec motors????
- random's stuff
- KIA vs HYUNDAI No war here
- phenolic IM spacer
- For those with a gutted cat
- Intake
- Random Special is on
- catbacks
- Big Bore Throttle....
- New ECU under development... long
- Random S-AFC, Not found in Search
- Itakes
- Power steering resorvoir
- Carbon Fiber Cold Air Intake
- 1987 supra
- Switching a MAP to MAF *RED*
- TB bypass
- As of 00:22 MDT this morning, the Haltech is alive...
- O2 sensor after the Cat???
- To people with aftermarket oil caps
- K&N Filter any good?
- 2.5 in/out p/n glasspack
- torque
- Will This One Work...
- S-AFC gains (yes i searched :p)
- Gen 1 S-AFC MAP or MAF
- install a tachometer
- IM and COOLING
- Red / Random 14.9 NA
- Spark Plugs
- Barney BBTB question
- afterburners
- LET'S GET THE DEBATE OVER WITH!!!
- Headers and 02 censors.. :)
- Exaust
- engine cover
- AEM Update
- Hi-Octane Fuel
- Engine Idle
- Engine Forum Searches and Full Searches.
- Pulley Kits?
- Glasspack size....???
- Exhaust noise!!!
- Fuel Fitting
- A beautiful thing!
- BIM and BTB groupcircle/groupbuy thingie
- Hyundai Project update: engine is in...
- RSM-GP stats
- Monster tach
- Steel Braided Hoses
- cruise control on BBTB
- CAI question
- TB and IM uninstallation guide please
- Is there any way?
- Barney TB question
- Replacements
- Cold Air Intake: MHP or AOS?
- Tornado Air
- What makes that sound?
- cel code
- put my race muffler on
- IM again....
- For those who like to visit the DYNO.
- Best tool set for engine mod?
- Another exhaust question
- RSM-GP project done!
- XD Cam?
- Intake air velocity
- Better take off when I'm not flooring it?
- Idle air bypass bosch thingie :) FYI
- CAI - Which is Best
- my custom made short cai [Warning about 5 images inside]
- RSM ecu wiring harness
- High Flow injectors??
- BIM/BTB Project! DONE!!
- exhaust ?
- Mod List
- Throttle body plate question
- Bored throttle body
- a cure for 2.7Ls fake duals..
- stock 2.0
- New Cam for a KIA?
- O2 Sensor wiring
- Best Power Gain
- SMC Stainless Braided Brake Lines
- e-Manage
- Intake Manifold
- Most hp from stock 2.7L
- HDK Autosport headers
- so i was looking through this months super street...
- Finally made the CAI
- Engine color scheme
- Cam Gears
- Intake Mod
- basic maintenence questions
- No longer sad about MAP
- fake duals on 2003
- Running rich....
- Great videos
- total cost of mods
- LSDs?
- Transmission Problem
- Question to people who have the XD cam installed
- Low End Power-Random/Red/Anyone?
- Fuel and maxhp questions?
- Headers and Cat
- hypercharger
- will your engine blow?
- Cam source..
- I need to get into the mid 14's
- S-AFC Question
- header question
- Stainless vs. Aluminum
- Port n' Polish
- Any one familiar with RACtive performance parts?
- 70,000 miles?
- Power Loss
- Power Loss
- Boring IM
- i need your OPINION
- For those DIY 4-2-1 header folks
- URGENT !!!
- motor vac
- Extend O2 wires?
- Popular Modification Site URL Request
- Q about Custom air intake
- Request
- Remus Exhaust
- Installing 2.0 GT Cam today, quick questions!?
- maybe a dumb question about auto trans.
- Concerning AOS CAI filter...
- EXHAUST IS IN!!!!!!!!!!!!!!!!!!
- What is this TB part/switch?
- Fuel Pump Replacement...
- metal mesh hose kit
- question on resonator
- SSHHHH!
- s-afc
- Those with automatics
- Air Fuel meter installation
- Warranty??!
- limited slip differential
- 2 CATs???? WTF???
- Intake Filters
- Computer Chip
- oil pan
- exhaust suggestions?
- could anyone please...
- 4-1 Headers Dyno
- Random... CAI MAP question.
- New Cat-Back questions
- valve chatter?
- Stock exhaust manifold
- ...kicked my butt!!!
- Bored IM
- Ractive Exhaust Muffler
- What should i check??
- Spark plugs #1 #4
- little confused, before its little too late
- Brands and Difficulty
- Some pics of Shadohh's auto to manual conversion...
- Tornado
- Exhaust Question(Again...)
- Exhaust appointment-FINALLY
- Metal Hose Kit
- MBRP Speedstate exhaust fix
- OEM Airbox MOD --> CAI
- all-around exhaust-engine etc. question
- Coolant question.
- Wierd, no speed limiter?
- I want to say...
- Hi-Perfomance Mufflers
- Engine gurus: If you had your pick....
- ngk plug wires
- pistons
- Exaust
- 2 1/4 or 2 1/2 inch piping?
- The HyundaiProject website is coming back...
- cat-back today! :)
- Cost of a new Cat back. Team SR?
- diy cai
- Exhaust back-pressure theory
- MBRP VS BRULLEN
- 4-1 headers
- CAI ???
- Is it necessary to change ECU?
- new exhaust
- 4-2-1 Headder
- Cat-Back Exaust
- Random - HP per mod?
- OH MY!
- Max-Flow High Flow Catalytic Converter
- Check Engine Light
- Intake Vs. Power
- Apexi safc wiring
- Is this intake any good????
- Clogged catalytic converter
- Did I get a right glasspack this time?
- Arizona and catalytic converter law
- Intake Question for Random
- GT cam/Tuneup/timing etc etc
- Hi Flow Cat and Exhaust work
- For those of you who have switched over to the GT cam or the 1.8
- Intakes
- Exhuast Problem
- Rev Limiter
- exhaust is done
- Is this for real?
- intakes ??
- Slight change in timeline plans for my project...
- headers diameter?
- DIY CAI Done at last.
- 2003 Fuel Pump...
- torque convertor?
- Timing belt...
- Pics of engine components
- Harness on the intake?
- Caps and such...
- Thankyou Ballistic Racing
- Throw away the IM...
- mbrp exhaust
- dual and quad throttle bodies?
- RPW Engine Upgrade
- Piston Rings??
- Hey Onpol/Red
- How long is your glasspack?
- throttle body with stock IM
- Heat wrapping intake... Few questions
- Throttle Body
- Will SR header void my warrenty?
- Seriously lost here!
- Downpipe that adds 25+ hp and torque?
- Searching for...
- exhaust ? for random
- high flows cats
- What Size resonator?
- Apexi RSM-GP
- Ebay exhausts me...
- Thottle body install?
- gt cam q's??
- Engine Management
- mandrel bending question
- SHIFT KIT
