To people with aftermarket oil caps
Old May 1, 2002 | 08:31 PM
Xorro's Avatar
Vehicle: Mitsubishi Lancer Ralliart GSR
Default To people with aftermarket oil caps
Has anyone found an oil cap that fits the tib (apart from the KORE ones)?
If you have I wouldn't mind knowing where you got it from, and it would be great to see a pic!
TIA
Old May 2, 2002 | 12:03 AM
Reid's Avatar
I had one on my car for a while, but it rattled loose and fell off going down the freeway one day...it was for a 1st gen Eclipse engine, but they will work in ours as well. (not the screw in type)
Old May 2, 2002 | 12:31 AM
Xorro's Avatar
If I get one it won't fall out like your did will it? :eek
Old May 2, 2002 | 09:38 AM
Xorro, I asked this same question some time ago myself. The answer is that the Mitsubishi caps will fit, some loosely though. If it's loose, you should just have to put an extra rubber spacer on it to tighten it up.
Old Oct 4, 2012 | 09:16 PM
Red Raspberry's Avatar
Try one made for a Ford.
Old Oct 5, 2012 | 06:39 AM
Congrats on raising a 10 year old thread!
Old Oct 5, 2012 | 07:14 AM
Congrats on using search!!
Old Oct 5, 2012 | 11:57 AM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Well since it is back from the dead, I bought mine at pep boys in 05ish for the beta 2 engine, it was for imports and did list honda as a fit if I remember correctly. Wasnt sure if it would fit or not but it did with no problems except sometimes it is hella hard to break free but then spins off, no other problems and im still using it today.
Old Oct 5, 2012 | 03:30 PM
songee623's Avatar
Vehicle: 2005/hyundia/elantra
yeah if its a beta 2 the honda caps work i have one on my 05 elantra and my 09 v6 santa fe.
