Wierd, no speed limiter?
Old Apr 13, 2002 | 12:12 PM
Decker's Avatar
Default Wierd, no speed limiter?
Ok, today found a nice open road and took my tibby to 135mph and I was still going before I ran out of road tho.
But the only think I can think of that would cause this is the S-AFC? but i don't think it has that ability? is it possible that they forgot to program it at the factory?
[ April 15, 2002, 12:01 PM: Message edited by: Decker ]
Old Apr 13, 2002 | 01:12 PM
SilverTibby's Avatar
No, you might need to calibrate your speedometer.
Old Apr 13, 2002 | 04:00 PM
Veniston's Avatar
yea, our speedos can have an error of up to 10% by factory spec, add in the fact that the supplier may not meet this spec and it could even be larger. Quality ain't job one rolleyes.gif
Old Apr 13, 2002 | 06:02 PM
MAXXTIB's Avatar
Does that mean that the mileage is off to, if its reading faster than so is the amount of miles you are driving going faster than it should making your warranty shorter. eek!
[ April 14, 2002, 01:04 AM: Message edited by: MAXXTIB ]
Old Apr 14, 2002 | 03:22 AM
Decker's Avatar
The strange thing is that I supsected a my speedo being off because
1. i chaned the inserts myself
2. I was maxing out at 110 for a while
i changed fuel and ran some injector cleaner and i got my power back so I was up at 120 for a while. On the way down to gulf shores i had a followed a buddy with a prelude and we matched speeds at 50mph and 80mph using a walkie. so I know my speedo is at least accurate around there.
but I still want to see if its really true or not. so is how can I recalibrate the speedo? so I can do it again and take a picture?
Old Apr 14, 2002 | 03:25 AM
WhoopOi's Avatar
My stock tib topped out at 135.....
dunno.... then when it went into the shop.... after it came out, it topped out at 125.. oh well
Old Apr 14, 2002 | 03:54 AM
Viper966's Avatar
ive had mine up to 123 racing a crx on the thruway, it still had some balls left, i didnt
Old Apr 14, 2002 | 04:41 AM
WhoopOi's Avatar
I know what you mean, at high speeds, I usually don't like it... I hit about 110-120, and I shut her down... smile.gif
Old Apr 14, 2002 | 05:42 AM
Decker's Avatar
i dunno, i just got a alignment and it seems to run nice at that speed. I'm going to be getting the Apexi RSM-GP controller, which will tell me digitally what my speed is. so i can see how accurate the speedo is. but i've never found that point where there's a fuel cut-off, well at 7.5Grand, but that was on purpose wink and my s-afc told me that I was 7448rpm. Which scared me because I know its not supposed to go past 6500rpm.
anyway, i'll get the rsm-gp installed and take it to the track. I was riding with a buddy in my car as well.
another thing that i did with my ecu was originally wire the s-afc backwards so when I cut that AF sensor(which was something else) i had to reconnect the wires that I had cut with a thicker 3inch piece of copper cable. Which i could act like a resistor and throw whatever that cable was off right? anyway. I don't want to get any BS flags so i'm going to get my gsm installed and see what speed i was really doing. because if my tire calculations are correct, I was doing
135mph(speedo)+3.498%(205tires)=139.66MPH! eek!
Whats the fastest anyone has gotten their tibby up to? I know there was a claim of 150 before, but don't know if that was confirmed? If possible could one of you guru's tell us what the maximum speed can be with the gear ratio's and hp? I think i remembered that you'd need 200+hp to break 150mph right?
PS(thinking about it, i do have a turbulence sticker, doesn't that add 50hp and remove the speed limiter!
[ April 14, 2002, 12:47 PM: Message edited by: Decker ]
