PDA
View Full Version : Engine, Intake, Exhaust
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. How often do you guys change your spark plugs?
  2. Adjustable/vernier camshaft pulley
  3. Is 4000 miles to long to go between synthetic oil changes?
  4. Building a catback out of PVC
  5. Anyone used Civic Radator (sizes help)
  6. Engine compents... Shades of white ? lol
  7. Under drive pulley or BBTB? Which is more noticeable?
  8. O2 sensor placement
  9. cold air intake hardwre prob plz help
  10. Battery with 675 CCA -- not good?
  11. Haltech on stock engine
  12. does a torque damper actually work?
  13. Ferrea Valves Fail!
  14. wont stay on..
  15. Air problems
  16. Where did you ground your wires?
  17. 4g63 on coupe 2006?
  18. fuel mileage
  19. Show off your valve cover
  20. Putting a decomp plate in the way
  21. Pod Air Filters Mythbusted
  22. Engine Balancing
  23. Octane Question
  24. Fuel Efficiency
  25. Throttle freezing open
  26. Exhaust set-up
  27. Anyone ever stripped a drain plug?
  28. Elantra 2.0 How to advance timing on crankshaft plate???
  29. Low oil lights
  30. CO2 emissions are interesting
  31. Mobil 1 Deal From Pep Boys
  32. Engine displacement
  33. When relocating the battery to the back
  34. LULZ at Lucas Oil
  35. Oil question
  36. How much is to much, crank case vacuum?
  37. How to properly setup the O2 sensors w/o stupid stuff
  38. Ignition/Coilpacks
  39. beta oil pan gasket
  40. Installing 1.8L cams
  41. O2 sensor bung tap size?
  42. A/C and gas mileage
  43. Any problem mixing oil with different weights?
  44. Catted or Catless
  45. Milled head.. Do i need higher octane
  46. Greddy Emanage Blue
  47. Fix your loud exhaust
  48. Cheap Tune
  49. High idle/jerk under engine brake
  50. Have you ever had an old person scream at you for your car being too loud?
  51. Modifying the Intake Manifold?
  52. Beta1 vs Beta2 intake manifolds
  53. what exhaust to get on tiburon
  54. What exhaust to get
  55. Should aftermarket rods have any movement on the crank?
  56. Wanted: OEM headers with cat for Beta 1
  57. Help me read the plugs
  58. best place for battery in trunk
  59. Kick push starting a car
  60. Can you use this stuff to clean an engine bay?
  61. Buying a used exhaust
  62. Apexi Neo on N/A Tib
  63. Camshaft Position Sensor Installation
  64. Alternator question
  65. voltage question for the advanced members
  66. Genesis Coupe TurboXS Exhaust Installed
  67. Hydrolocking with an SRI
  68. White smoke ?!?
  69. high compression pistons
  70. Check engine light came on but there are no codes
  71. Venom 400 Control Module
  72. Radiator and rad hose questions
  73. What can happen if you have an uneven bore in your IM?
  74. Is E85 environmentally friendly?
  75. They obviously dont care about hydrolock lol
  76. If you have a shop do an oil change on your car
  77. Optima Yellow Top on sale TODAY ONLY
  78. Alternator whine after battery relocation
  79. Cylinder bore gauges
  80. Think I might have blown up another motor
  81. exhaust rattle
  82. How many engines have you blown up?
  83. Filled motor mounts with a torque damper?
  84. TB Mods
  85. Vid of valve float
  86. Wire Tucks
  87. Beta II head on Beta I engine, any gotchas?
  88. How to clean out bolt threads on block?
  89. Oil weight switch
  90. How many N/A people have actually had their car dyno’d?
  91. Anyone regret the exhaust they have?
  92. Visual differences
  93. Under $50 engine mods
  94. A simple question regarding engine mounts
  95. Oil drain valves
  96. Checking oil level
  97. What header do you N/A guys have?
  98. Bad gas cause weird idle problem?
  99. Stock rods
  100. MyAMSOIL garage
  101. How salty is your engine bay?
  102. Battery relocation positive cable?
  103. Rotella affecting AFR's
  104. piston question
  105. Stalling engine
  106. Oil question
  107. knock sensor
  108. Pacemaker headers?
  109. Head scratcher
  110. valve spring compressor tool
  111. Removing rust on bolts
  112. When testing fuel pressure
  113. Rough Idle
  114. Can you ceramic coat pistons?
  115. Train horns not loud enough for you?
  116. Yellow stuff in catch can
  117. Rotten egg smell
  118. Radiator slim fans
  119. Dumb question about RPM
  120. Efficiency
  121. What causes a timing belt to skip?
  122. Lets talk variable displacement motors
  123. Question regarding exhaust leak
  124. Port & polish cost
  125. Hypereutectic vs. Forged Pistons
  126. Fuel consumption question
  127. Fuel Filter Replacement: Could Be Harder
  128. New exhaust for the GenCoupe...
  129. Low oil light, loss of power, knocking, won't idle
  130. Coating Headers/ Extractors
  131. Lucas Oil Stabilizer
  132. Turbo exhaust
  133. Oil pressure help
  134. Piston expansion
  135. dynamat hoodliner neg effects?
  136. Starting a car in cold weather
  137. Aftermarket Radiator Caps
  138. Idea of adding extra oxygen into intake path....
  139. Grounding Kit
  140. whats good for machining stainless steel flanges flat
  141. Why does 01' tiburon have TWO catalytics?
  142. My Genesis Coupe Exhaust
  143. Stroker kits
  144. Aftermarket cams model number location
  145. Does it take more gas to start the car than to idle for a few mins?
  146. Seafoam bad for cats?
  147. beta 1 head bolt up to a beta 2 cvvt block??
  148. spark plug shelf life?
  149. Some in depth details on the Alpha series of engine.
  150. How many people have their car tuned for E85?
  151. How Its Made
  152. How do you define knock count?
  153. What set of Eagle rodscan be machined to fit the Beta?
  154. adjustable cam gears
  155. Oil accumulators?
  156. Weak Link: Stock Rods or Pistons?
  157. Titanium or Fiberglass Heat Wrap??
  158. Oil question
  159. Does Synth oil cause engine ticking over time
  160. Can Engine Survive A Little Bit of Oil Starvation and Recover ?
  161. If your car is slammed
  162. Fact or Myth
  163. Fuel pump rewire
  164. HLA vs solid, which would be better?
  165. Compression tests
  166. clean engine
  167. PnP throttle bodies
  168. Phenolic Spacer for Genesis 2.0
  169. How to track down fuel leak?
  170. which exhaust tip for a rd1?
  171. What fluid leaks have you sprung?
  172. Blown HLA's
  173. what other modifications can i do to my engine?
  174. Underdrive pullys bad in cold weather?
  175. Shell "Nitrogen Enriched Gas" ?
  176. Fuel Chilling System?
  177. question about Optima Red top battery
  178. cruise control?
  179. What kind of muffler do you like better
  180. Another Ticking/knocking engine
  181. What size is the oil drain plug in mm?
  182. Aftermarket cams and oil viscosity?
  183. German Castrol Oil?????
  184. What can you use to clean the MAF sensor?
  185. Replacing the battery for winter... any suggestions?
  186. Advice on coolant change
  187. Brake booster lines
  188. autozone: duralast spark plug wire issue/solution
  189. oxygen sensor wire identification
  190. Engine Builders: Can Detonation cause a spun bearing?
  191. Torque Dampers on an N/A car
  192. How to identify reflashed ecu
  193. Better MPG with name brand gas
  194. New waterpump with every timing belt change?
  195. Why do our cars have 2 catalytics converters?
  196. Flooding the engine
  197. Best Replacement Filter for Aemv2
  198. Will raw aluminum corrode?
  199. Tranny fluid with oil
  200. XD Elantra Exhaust interchangability
  201. Tune required after installing lower comp pistons?
  202. Wiseco rings work with stock pistons
  203. Exhaust wrapping
  204. Replacing the horns
  205. MAP vs MAF
  206. Whats the difference
  207. Valve Adjustment for performance
  208. things i make....
  209. Engine Hacks
  210. were to buy good exhaust
  211. Seattle Times: State phasing out vehicle-emission testing
  212. cleaning engine internals
  213. Iridium spark plugs
  214. Non synthetic to high mileage synthetic
  215. Wideband Install Tactics
  216. $20 OBDii scanner
  217. Circuit breakers
  218. Alternator Charging Voltage vs. Temperature
  219. Oil Weights
  220. 0W30 oil
  221. Intermittent Poor Running Engine Beta LC Accent
  222. advancing the timing
  223. Extrude honed?
  224. royal purple
  225. Dual exit
  226. Dows chrome plating hold in or deflect heat?
  227. Engine HELP
  228. Headers and Emission Testing
  229. Cleaning air filters
  230. Misfire from Hell!
  231. grounding kits
  232. Mystery Stumble/Cut, Then NO Run/No Start For a While
  233. Your thoughts on header design
  234. How good are dynojet dynos?
  235. This is so flippin bad ass
  236. 2.7 cam in a 2.0?
  237. Spark Plugs......
  238. DEI 010396 Reflect-A-GOLD
  239. trying to calculate max rpm for a beta
  240. Catback vs headers.....
  241. Leaning out at higher RPMs
  242. SAFC good to have for bolt ons?
  243. Mirror film for under the hood
  244. 18 hp with just a header?
  245. Beta valve sizes
  246. Lets chat about overboring
  247. Fog light duct for ram air
  248. 02 sensor and high flow cats
  249. what color wire is the signal wire
  250. Side exit exhaust
