Exhaust wrapping
I have heard that heat wrapping a header will cause moisture to get trapped underneath and make your header rust pretty bad. Is this true? I dont want to end up with a header that has rust holes in it because I thought heat wrapping was a good idea.
get a stainless steel header?
and when the header is super hot most of the time, i don't see moisture being much of an issue. how much water would be getting on the header anyway? driving with your hood off?
