were to buy good exhaust
Old Aug 24, 2011 | 07:52 PM
MINKISS's Avatar
Vehicle: 02/Hyundai/Elantra GLS
Default were to buy good exhaust
anyone know a good retailer to get a good exhaust for and 02 elantra (beta2 motor)that wont through a CEL cause ive tried and tried agian to get this one to work and not throw a CEL and have prob spent will over $2000 in the procces.
Old Aug 24, 2011 | 08:41 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
LOL when you install the 2nd o2 sensor, or the one after the cat you will need this....
No more CELS
This will keep your CELS away, no need to spend money on exhasut if you remove the cat, you get a cel, yet it is easy to fix. No worries there!!!
Old Aug 24, 2011 | 09:25 PM
MINKISS's Avatar
No more CELS
i tryed that already and still got CEL on second o2 sensor but hears my new question that just poped in my head and is prob my problem (feel real stupid right now lol)are you soppose to use that with or without a cat cause as of right now i have a cat between the 2 o2 sensor its mainly right before the 2nd o2 sensor
Old Aug 24, 2011 | 09:58 PM
head
header with 02 sensor
cat
02 sensor
pipes
Be sure the sensor throwing a code is actually working, and that the converter is rated for the application, before spending more money on a new exhaust.
Old Aug 24, 2011 | 10:59 PM
To answer you question if you have a Cat, you should not need the sensor extender bung, I would read the codes and make sure the wires to the sensor are in good shape then if the wires are fine and you come up with a code saying something about the specific sensor try to find another wheither it is new or used to do some pop and swap testing!
I am running my stock sensors on a 3" straight pipe and just use a senso extender on my secondary or after Cat and i have never had CEL for a inproper CAT, That was the best 15 dollars i ever spent.
Old Aug 25, 2011 | 02:18 PM
MINKISS's Avatar
i have a pipe without a cat on it i might try to use that i guess and see if it works out with the sensor extender seeing as im guessing you dont have a cat on your car correct?
Old Aug 25, 2011 | 07:50 PM
I have a 3" straight pipe from the Turbo all the way to the back of my car with a Fart can for show....
I have no cat and no real muffler...
Old Aug 25, 2011 | 08:18 PM
MINKISS's Avatar
ok ill try and use it with out the cat and see what happens
