Radiator slim fans
Old Jan 31, 2012 | 01:10 PM
textib's Avatar
Vehicle: 2005 Tiburon
Default Radiator slim fans
Do you have to hook these up to a manual switch or can you splice them into the stock wiring so they come on just like OEM fans?
Old Jan 31, 2012 | 01:14 PM
Red Raspberry's Avatar
Most fans I've seen draw over 30A. It would be unwise to use just a switch. I would use the OEM harness to fire a 40A relay circuit that you install to power the new fans. Or use the OEM harness but be sure to use good heavy duty means for splicing.
