Beta1 vs Beta2 intake manifolds
Old Jun 5, 2012 | 08:14 AM
eggcatcher's Avatar
Vehicle: F2 Evolution
Default Beta1 vs Beta2 intake manifolds
Been thinking, maybe overthinking, but I've noticed the shape of the Beta1 and Beta2 inlet manifolds are completely different, one has short fat plenum with short runners (Beta2), other has longer, much thinner plenum with longer runners (Beta1). Would there be any performance gains in putting a bet2 intake on a Beta1?
I know the idle air is external, and I'd need to connect MAP up somehow, but I have plenty of pipe fittings at work, so drilling, tapping and putting an NPT pipe fitting won't be a problem.
Old Jun 5, 2012 | 11:44 AM
rd2twisted's Avatar
Vehicle: 2000/tiburon
yeah the beta 2 has 20mm longer runners and an 8% smaller tank it would give you some gains on a n/a motor.
Old Jun 5, 2012 | 01:00 PM
eggcatcher's Avatar
Unless UK specs are different, it's the Beta2 has the shorter runners.
Old Jun 5, 2012 | 01:16 PM
rd2twisted's Avatar
its possible have you taken them off to look at them 20mm isnt alot
Old Jun 5, 2012 | 07:13 PM
silvershark78's Avatar
Vehicle: 2004 Lincoln Aviator
unless it is because you are not from the US, get a beta 2.5 manifold with the maf based setup. 2004 to 2006 elantras. If you have a map setup in your tib I dont have any advice. Consider the manifold from the HD elantra as well. some have speculated that it has a higher flow capacity
Old Jun 5, 2012 | 11:38 PM
eggcatcher's Avatar
Im from uk. Our gen3 tibs are hd not gk. Will get pics of the 2 i have and post them, best way to avoid confusion.
Old Jun 6, 2012 | 07:24 AM
so is your coupe a maf or a map based system. and by beta 2.5 i meant the cvvt version. i know there was never really a 2.5 but sometimes it is refered to as that
Old Jun 6, 2012 | 08:48 AM
eggcatcher's Avatar
Its a cvvt manifold i have spare. I know its a MAF engine, and my current tib has an older MAP, but i can sort that, and idle control. What i want to know is whether its worth trying?
Old Jun 6, 2012 | 11:44 AM
eggcatcher's Avatar
These are the 2 I've got, the one on the left being from a Beta2, the right one a Beta1.
Also, whats this extra hole for? It's on 2nd runner from the right.
Old Jan 31, 2020 | 12:00 PM
427troy's Avatar
Vehicle: magqualaVE
Default 25.4 mm = 1 inch
20mm is allot.
Related Topics
Thread
Forum
Replies
Last Post
likeyoumeanit
Engine, Intake, Exhaust
12
Jan 18, 2009 12:45 AM
ETXorangetib
Hyundai Tiburon Forum
3
Aug 3, 2008 02:39 PM
Suprgtrs_man
1
Sep 25, 2002 01:09 AM
Random
27
Jun 19, 2002 10:38 AM
Zman
4
Jun 17, 2002 12:32 AM
