Milled head.. Do i need higher octane
Old Jun 15, 2012 | 11:22 AM
Twisted385's Avatar
Vehicle: 2000 tibby
Default Milled head.. Do i need higher octane
If you have your head milled and use low compression pistons, is it required to use premium octane gas or can you still use regular?
Old Jun 15, 2012 | 12:43 PM
epinero's Avatar
Vehicle: 1994 Hyundai Excel Coupe
If your all motor you should be fine with regular. If your turbo use premium regardless of compression. What's your set up?
Old Jun 15, 2012 | 06:57 PM
Tibbi's Avatar
Why would anyone spend that much on head work to then install low comp pistons UNLESS boosting or spraying.
Short answer to your question, no. However, if you did all of that and increased the compression very likely.
