Throttle freezing open
Is it possible for our throttles to stick open if I were to drive the car in extremely cold weather this winter (Minnesota gets pretty darn cold)? I have done the coolant bypass mod but I may return it back to stock since I have heard cold weather can hurt the car with this modification done.
They put them on the TB for a reason. I also know the LC accent I had (first year run of the 1.6) had some sort of recall on it concerning it being possible for the TB to freeze and it had the coolant lines running under it 0.o
You might put a valve on the line if you can get one cheap, so you don't have to keep messing with coolant hoses every year. I would probably leave it and maybe check on it every once in a while, if that. The concern is with long-duration runs at constant throttle in superduper cold weather. In traffic, it will probably be working enough to bust up any ice that might form. On a long highway trip, the ice might build up if you just steadily keep the gas in the same position.
I've bypassed the TB hoses on the last 4 cars I've had and never had a problem in over 20 years. I live in Northeast Central Illinois where it gets good and cold.
