Putting a decomp plate in the way
Old Aug 31, 2012 | 02:11 AM
wheel_of_steel's Avatar
Default Putting a decomp plate in the way
Just a thought
The beta has pretty nasty geometry because of that diesel-length stroke. One of the problems that it creates is the rods have to be rather short so the engine isn't tall as f*ck. Then having short rods means that they end up taking lots of bending load, especially at high revs. Look up rod/stroke ratios if you want a better explanation, it makes for interesting reading. Anyhoo, engines like the B16, 4AGE and 4G92 all have R/S ratios around 1.75, this is definitely a desirable target ratio.
I was thinking about improving the R/S ratio by using a 1.8 crank in a tall 2.0 block with custom longer rods, but that only does so much. What about using a decompression plate to lengthen the block? I know they are usually used to lower compression; ie the piston never crosses the boundary between the plate and the regular block... I wonder whether the rings would care or what? I made a picture to illustrate my point:
I would like to hear your thoughts.
Old Aug 31, 2012 | 08:51 AM
OTECTom's Avatar
You drew penises.
Old Aug 31, 2012 | 08:54 AM
my issue is with the rod being longer, you might be able to clear the stroke
have to notch the sh*t out of the block
Old Aug 31, 2012 | 09:39 PM
The rings would be chewed to pieces unless you did something very expensive to the joint between the plate and the block, or you did something VERY expensive with the pistons.
Old Sep 1, 2012 | 07:15 PM
yellow01's Avatar
Vehicle: 01 tib t3t4
stocker is correct exactly what I was going to say
Old Sep 1, 2012 | 07:27 PM
300D50's Avatar
Would require sleving the block with the decomp plate in it, and getting coolant passages and such sorted...
Long story short, PITA to do...
Old Sep 1, 2012 | 07:57 PM
Probably cheaper to use an entirely different family of engine with the geometry you wanted and fit the engine bay to the new powerplant.
