MAP vs MAF
Old Sep 4, 2011 | 03:11 AM
kostask's Avatar
Vehicle: 2001 hyundai turbulence
Default MAP vs MAF
I have a question someon know if in a beta engine with MAF becom conversion to work with MAP?
Sorry for my English not very well...
Old Sep 4, 2011 | 07:40 AM
wheel_of_steel's Avatar
what year of engine?
but on the whole, you can't just convert, the sensors output different signals. If you wanted to convert your sensors, you would have to convert your wiring loom and computer too man.
Old Sep 4, 2011 | 11:30 AM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
You can depin the maf and repin it as map, thats what I did but the the ecm will need swapped. Also im not sure but im guessing there is no spot on the surge tank (is this the right name?) for the map sensor to sit so that may need swapped. depending on years of you current ecm and donor ecm you may have to rewire the ecm itself.
Old Sep 5, 2011 | 07:07 AM
kostask's Avatar
I have a turbulence and I want to put the beta engine and four-wheel drive from tucson and want to keep the ECU from tucson to control the four-wheel drive and want to convert to MAP for high boost if I put a turbo
Old Sep 21, 2011 | 10:18 PM
yellow01's Avatar
Vehicle: 01 tib t3t4
I know 100% that with aem fic on tiburon you can convert from maf to map. But im not sure how similar the ecu is on the tuscon.
