Low oil lights
Old Aug 2, 2012 | 06:32 PM
01whitetibby's Avatar
Vehicle: 01 Tiburon
Default Low oil lights
I often wondered why Hyundai never included a low oil light on the dash like many other car makers do. Then again maybe its a good thing since I know tiburons specifically run low on oil sometimes and have HLA tick from oil starvation. So the light would be on all the time.
Old Aug 2, 2012 | 09:31 PM
wheel_of_steel's Avatar
Cost-per-car issue, I suspect.
I'd like to get an oil pressure switch that activates at a higher amount of oil pressure, so I have a bit of advance warning when the engine fucks up. Rather than getting a light turn on when there's only 2-3 psi of frothy oil left.
Old Aug 2, 2012 | 09:39 PM
id rather have a oil pressure gauge that tells me exactly what the oil pressure is
also i thought tibs did have a oil light?? iirc wasnt it on the right upper side of the gauge cluster?
Old Aug 4, 2012 | 08:22 PM
krazytib's Avatar
My 01 Tiburon has a low oil light on the right side of the dash in between the brake and engine light.
