- Weeping Oil Filter Housing... possibly
- Overheating after Timing Chain replacement
- 2006 Accent Atlantic Exhaust alternatives?
- Need questions answered (01 tiburon)
- G6DA-AT alternative
- 2.5 diesel iload engine
- Timing issue
- Beta 1 Intake manifold modification
- Rd1!?
- Hyundai getz engine swap
- Airram intake
- Exhaust manifold
- Some carbon fiber goodies
- Vin Decoder Feature
- Intake tube sizes
- Megasquirt Issues 2: Electric Bungaloo
- Mobile 1 Rebate
- Ticking HLA's
- Wish there was more tuning options
- How many of you had one of these years ago?
- Ryco air filter or k&n filter
- Engine knock??
- Good trickle chargers
- Do you change your exhaust often?
- Easiest way to measure AN fittings?
- Map Sensor Location
- What are you guys doing all your old oil?
- Megasquirt acting screwy
- Potent Boosters
- BG 44K Fuel System Cleaner
- Stripped power cable
- If your car is making noises
- Ecu swap on x3
- Things that make you go hmmmmmmmmm............................
- Poor workmanship
- Que me recomiendan para que mi beta 2.0 corra mas y tenga hp
- Intake Location
- Show your clean engine bays
- Beta 2 Hi Po Cams?
- Beta1/2 ACL Race Bearings?
- What header are you driving with?
- ECU learning
- Airram Flow Test
- Disappointing Dyno Numbers
- Straight piped Tibs
- Floating rods and pins
- Engines to get a whole lot more complicated
- Hyundai Tucson Intake
- rebuild engine, reuse bolts?
- 1.8 pistons
- Americans waste $2 billion a year on pricey premium gas
- piston to valve clearance?
- Semi synthetic oil changes
- Engine cranks but wont start, slowly loosing vitals.
- Injector question
- Does polishing the outside of your IM offer any performance benefit?
- The raw sound of the new 2.0L turbo for the i30 N
- 03 tiburon getting turboed
- Engine Quiz
- Opinions? Conversion to 2.0L + CVVT
- How many grades of gas do you usually see at one station?
- Opinions on OBD2 scanners
- Timing belt keeps walking
- Tried my hand at hydro dipping...
- Finally got around to installing a catch can
- The Power of 2.5- vs. 3-Inch Exhaust
- Piggyback tuning worth it on NA?
- Show off your engine
- Engine Dress Up Ideas
- 97 elentra
- aem fic6 need base tune
- Interim motor build
- Any worries about using silicone hoses?
- Engine Blocks
- Beta 2 Head Work
- Summer Gas
- Longer duration on intake camshaft?
- 1.8l cam and pistons in 2.0l
- colt regrinds
- Ontario station mistakenly pumps diesel instead of gas; damages multiple cars
- Good engine cleaner for only a dollar
- Who used to have chrome film under the hood?
- Duplicolor Metalcast
- Compression questions, engine questions.
- hundai i10 big end and main bearing torque specs
- Oil pressure test
- Duke Engines
- Finally needed a new cat
- Msd dis 4
- Cold air = more fuel
- What weight oil do you run in the winter?
- Decided to do a heart transplant
- Maximum Power on Stock RD Coil Pack?
- Beta head cross section
- DSM valve train
- Catch Can Thread
- Intake question
- Timing belt versus timing chain
- Mechanic scams
- anyone seen these before?
- Think my MAF went out
- Spark Plug Gap
- Find ethanol-free gas near you.
- Project Boosted Tiburon
- Fidanza adjustable intake cam sprocket
- VVT Technology
- Antifreeze
- Looking to Buy a Megasquirt
- Beta 1 2.0l exhaust cam on the intake said
- Exhaust test sound vid
- Default the best for you is the best,speed up!!!!!
- 1.8 exhaust manifold
- Dialing cams
- Performace Chips Mythbusted
- Dyno vs aDyno
- BETA 1 and 2 Coil on Plug Mod
- Is it possible for an engine with electronic fuel injection to flood?
- O2 Sensors
- A question of torque (bolts not power)
- Stock Vaccum - Common Causes
- Does any company make performance cams anymore
- Best oil filter other than OEM
- Info on bbtb
- have i got a vacum leak ?
- Injen Hydro Shields
- PAR Engineering
- What kind of grease?
- 2003 TuscaniGT ECU
- MegaSquirt base tune
- Deep Cycle Battery
- Clickdrive
- what is this thing by the throttle body?
- Worth tuning n/a for now?
- BTR catch can group buy
- Timing Belt Broke - what to do?
- Awesome engine rebuilt video
- coolant overflow
- Muffler brand = signature sound?
- moving alternator to back
- Will these fit in the engine bay?
- Exhaust header
- We Have Ignition: Hyundai's Experimental Gas Engine Runs Without Spark Plugs
- Cleaning K&N cone filter
- HA!
- JDM Motor
- Hanging revs between shifts
- Completely stumped and I'm desperate for help
- saab injectors
- Do you keep extra gas with you
- Purple Power
- Swap problem?
- Hyundai Coupe 2.0 N/A Dyno
- Fuel economy continues to get better over the years
- I want an airhorn
- How well does your car start with the cold weather we've been having?
- Exhaust smell inside the car
- Oil light on
- UnBeLievable: Broke the Camshaft Timing Belt Pulley
- camgear
- plug and play standalone?
- Genesis headers with stock exhaust piping
- injector type?
- How much power do cats steal?
- is the ecm the culprit?
- Were air rams the only aftermarket intake manifolds ever made for tiburons?
- Who builds the best engines in the world
- 2nd gear bog
- Electrical
- Header heat shield
- winter project
- What kind of intake is this?
- Oil Restrictor
- How to make a cheap racing exhaust
- little plans/motor work for next summer
- 01 Tib Gas Mileage Going Downhill :(
- Why do aftermarket exhausts belch soot?
- stalling when gas is hit
- Synthetic Blend Motor Oil I'm Not Impressed With
- What voltage do fuel injectors use?
- custom exhaust help!
- lucas oil stabilizer
- Battery Tender and more?
- Gas treatments contatining alcohol?
- this blows
- Throttle Cable Brackets on Airram
- What happens during engine braking (when a car decelerates in gear)
- Torque plate for Beta
- Do cars throw check engine lights when a timing belt is about to go out?
- 3k rev problem?
- HELP! Code P0343 Camshaft position sensor
- Engine covers
- Engine Sludge
- Under the Hood: What is Torque? What is Horsepower?
- understanding a dyno machine
- AEM FIC guidance
- diagram?
- Good price for Synthetic oil. How much do you pay?
- my x3 problem
- Need help parts for a 05 accent
- Exide batteries
- Time for some new coolant
- interesting exhaust on this GK
- Fake NGK Spark Plugs
- check engine light after cold air intake installation
- Need parts for your KDM?
- Would You Pitch In to Get 1.8L Cam Swap Dyno Tested?
- just finished engine swap
- Still no life from atomic but...
- Sound from Apexi Exhaust
- Has anybody heard of or used www.horsepowerfreaks.com
- Cleaners
- Spray Paint vs Cheap Paint gun quality for an engine hoist
- Amsoil
- Engine experts plz halp
- Looking for a cheap engine with under 50,000 miles?
- Power to weight vs over all horse power
- Maintenance Lights
- Mod you like to brag the most about
- Exhuast Sensor Hyundai Accent onto Tib/Coupe ?
- Codes- p0133 and p0244 help please?
- Solar trickle chargers
- Heres one way to get rid of your used motor oil
- Radiator for hyundai genesis 09-10 V6 3.8L
- Evoscan
- Revitalized AirRam!!!
- Suggestions on muffler
- The magic of an ECU tune
- Replacing my engine
- Simple Green to clean engine bay
- XADO Atomic Metal Conditioner
- Deatschwerks or Walbro
- x3 question
- AEM FIC wiring
- 01 tiburon header/ exhaust questions
- Soap and water to clean CAI?
- How many people are riding with a crushed bent exhaust?
- I hope I don't have an engine problem
- Anybody have this where they live?
- How many miles did your engine last before it ate oil
- ARK issues - Genesis Coupe
- Short ram vs sticking filter on end of airbox tubing
- Do you have a strange oil change procedure?
- Finshing off new Exhuast. Questions ?(No power Exhuast issue Exhuast issues or Megasquirt ?)
- 1.8 pistons
- What brand of oil do Hyundai dealers use?
- Penetrating Oils
- Changing ALL the Fluids
- Spark plug tightening torque
- Benefits of High Pressure Radiator Cap
- Cherry Bomb Vortex Mufflers
