custom exhaust help!
Old Sep 4, 2013 | 10:38 PM
fronkkillsit's Avatar
Default custom exhaust help!
Well, started running my 2.5 inch exhaust (it is turbocharged) and came to a problem back by the a arm. Now.. is it okay to have the exhaust running in between like this guy did or no? Cause its the only way the exhaust will run.
http://www.newtiburon.com/forums/showthread.php?t=61733
Old Sep 5, 2013 | 12:02 PM
If you make sure it will clear at full suspension compression that's fine. You can also route under the center there but that'll be your low point.
