saab injectors
Old Feb 5, 2014 | 12:14 AM
fronk21395's Avatar
Default saab injectors
Okay so I found this set of saab injectors on eBay for $69.99. Looked em up. They have the ev1 feed. They're high impedence and 350cc. They're for my Turbo build so I can run a little more boost. Will these work? I'm almost confidential they will I just need some feedback before I buy them.
http://m.ebay.com/itm/201025489190?nav=SEARCH&sbk=1
Old Feb 5, 2014 | 04:57 AM
should work but that's not a whole lot larger of injector. it all comes down to how much boost you plan on running
Old Feb 5, 2014 | 08:24 PM
fronk21395's Avatar
I'm only aiming for 10psi. I'm getting a 190lph walbro too. Should that be enough fuel?
Old Feb 6, 2014 | 06:48 AM
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
I'm using the walbro-gss342-255l
http://www.highflowfuel.com/i-103850...1996-2008.html
Old Feb 6, 2014 | 08:02 AM
10psi is a generic term. will your car run with those parts? yes, but you are severely handcuffing yourself. if you ever plan on uping the boost youll more than likely quickly run out of fuel and will need to redo those parts again. if you NEVER plan on changing anything (boost is a drug) you might be fine. all comes down to you expectations of power
