- Getting stuck in gears?
- electromotive tec3
- Best cheap OEM mod
- Motoria catback and headers installed with pix (NO56K)
- P/s belt was loose,...
- how to know what engine - 2.0 or 1.8?
- 2.0 beta motor
- 1.8L install help
- high rev, n/a
- Where is the speed sensor located?
- Cat Converter Recommendations?
- P/s belt stopping...
- Shifting into 3rd...
- Radiator leak :(
- Name Another Engine Problem
- Name the Engine problem
- No thermostat = Problem?
- NO SS Exhaust in NY!!
- after market motor
- TP sensor adjustment
- Going from Auto to Manual
- Underdrive pulley install?
- IAT Location
- tranny rebuild
- automatic vs manual throttle body??
- What gives a bigger gain?
- Now I cant decide for what buy!!! help!
- ACT clutches
- Which one is better?
- 96TIBURON/96ELANTRA Engine
- Transmission prob.
- Cold Air intake
- I need piston dimensions
- Got a new clutch put in...
- Cel 0442 Need Some Help
- Going into reverse...or not
- Engine ticking after oil change
- bogging down
- slipping out of gear
- 02 sensor placement
- SSA Exhaust... why do you say bad?
- ECT Button???
- Auto Tranny Problem
- Engine swap
- anyone know if this fits?
- Oil in intake tube before throttle?
- How to clean engine?
- Engine Leakage
- Is something wrong? please help
- New engine...
- Clap?
- Engine Misfiring?
- overdrive button
- Got my Crank Pulley in!
- slip?
- how much did your Clutch job cost? and where did you get it done?
- *Engine dress up kit?*
- Looking for good clutch......
- Motor mount Poly inserts
- Shift Improver Kit
- tranny acting up
- High RPM?
- Spark Plug cover replacement
- Welding the Differential??????
- Question about A/T
- Headers/Exaust question
- Racing Transmission?
- Kspec Motor Question?
- stupid clutch
- clutch sensor?
- Better investment
- A/T question
- Timing Belt (crank bolt)
- autotragic death/where do i go from here?
- BAD DAY broken piston
- Yet another exhaust thread.
- MBRP Exhaust
- Help!! Car Wont Start! *cry*
- knocking?
- Starter
- Plowed through a snow drift... Now have a CEL?
- Gear sensor?
- Installing 1.8 cam
- Help need battery size !!!!
- Toga?
- Clutch won't move
- Spark Plugs
- Starter
- Which BBTB?
- cluch is stiff now its not.. PEDAL that is
- quaife lsd's
- HCI - Mar. '05.... huge write-up on the 4G63
- Tranny Flush? Easy to do, or should I pay too much?
- MSD DIS-2 Ignition .. pics
- Engine Running Weird
- ECU question?
- Belts
- Oil Catch Cans
- Wrench & Screwdriver
- tranny dropped
- New clutch in near future
- squeeeeealing
- Oil Loss need info
- Took off the exhaust manifold..ew
- Next Upgrade to make??
- Check out what I just scored.......
- About the 1.8 L cam
- Mitsubishi->Hyundai engine swaps??
- quick question
- Tib Tranny vs. Elantra Tranny??!?1
- Motoria 4-2-1 header quality Q's?
- 1.8L and 2.0L beta bearings
- Direct Fire Ignition*UPDATE*
- Tranny Swap
- Tell me more about manual trannies.
- obd-2 CHECKERS?
- Alternator Removal
- Hissing sound??!?
- Header O2 sensor headache
- Does anyone here know where to contact Dom?
- engine clearence
- water/alternator pulley
- MSD ignition help
- doing cam research
- The end of my car probs... or not
- Transmission swap, help please! Auto to manual.
- Bomz Cold Air Intake
- Exhaust bolts?
- 1.8 & 2.0 Head differences?
- Gear oil info, GL4 and Gl5 and MT-1
- KRD exhaust sounds good.
- auto tranny
- adjustable cam sprockets
- clutch...
- OBX Headers
- Help! I can take out key from ignition while i'm on "Dr
- Best Cheap OEM Mod Yet... *Teaser*
- Differances in clutchs
- Engine Splutters.. need help... chain of problems
- Voltage Regulator help
- Individual Throttle Body
- Engine sound...
- Anyone have contact with SS Autochrome?
- Winter oil...need some opinions
- Burning Oil...sh**y
- Wet compression test/leakdown test
- Oil Pressure Gauge HELP :)
- Car wont start cauz clutch engage only 1/2 while pedal floor
- Timing Belt Help
- Rebuild Kit
- Emissions? (SPLIT)
- Will i need an Safc?
- Transmission dead?
- Stuffed Clutch?!
- Tips for cleaning?
- Need Help ASAP!!
- A Shot in the Dark
- Is there a larger MAS?
- Bomz Racing Cold Air Intake
- Engine Rebuild
- rside shifter
- is this shifter any good?
- lsd
- Alternators
- more o2 problems!! (besides slipstreams)
- Beta 2 Valve Cover Conversion Kit Pictures...
- o2 sensor problems
- Port & Polish a Beta I head
- Anyone that bought a Jspeed crank pulley from KSpec read plz
- Weirdest electricity-related thing i've noticed
- Clutch problem
- RPM Bounce
- Engine Pulsates...
- timing belt
- new motor gona na tune.. no more FI for me.. what can i do?
- Tranny Irritating Me...
- AEM Bypass Valve: Sound vs. Integrity
- KSPEC ENGINE MOUNT BUSHING
- HELP: Why do I get the ticking noise?
- HELP!!!! changing clutch tranny stuck NEED HELP ASAP!!!!!!!!
- Can our tranny's handle boost
- Port and Polish info.
- High Oil pressure
- Got my AEM intake but missing part
- Oxygen Sensor wires
- cam/bbtb/airram related Q's
- Spark plug question...
- Oil in Radiator... Just Confirming
- Beta 1 or Beta 2
- running rich...
- Auto trany problems
- trans cooler/ filtration
- tranny identification
- Defroster is Broken!
- Muffler for 2003 I4 Tiburon...
- looking for literature
- Torque converter issues...
- auto to 5 speed ?
- engine mounts bushing
- RPM Signal.
- Gear oil
- pulleys
- OZ-BBTB
- FPR Fitting
- Stupid Question
- How big can you bore...
- gas mileage?
- Timing Belt
- factory defects
- Problem with Power steering/waterpump Pulley kit
- unmount main muffler
- *PROJECT BORLA (Failed!)*
- Part number needed for 01 Elantra cam...
- Radiator Hose
- 2.25in exaust w/ turbo?
- Oil change frequency
- I think there's something wrong with my clutch...
- Potential tuning ECU swap for RD cars from REAL
- Finally installing clutch
- grinding in second
- My new CAI
- My aliminum crank pulley
- e-bay clutch quality?
- Exhaust Manifold
- Clutch Alignment Tool
- Assembly Lube
- headers?
- VHR clutch IS IN!!!!
- auto tranny problems?
- Installing an Autometer Tachometer with Shift Light
- Fuel Management
- MBRP Exaust
- 01 tiburon shortshift questions
- new transmission friday!!!! Updated!!! - project completed!
- Engine boggs
- knock sensor and accel sensor
- ACT or Clutchnet
- OBDII specs
- FMU Vortec or CarTech
- my idle is AFU...HELP!!! *FIXED*
- AIM gasket
- *Exhaust Listings*
- Exhaust
- 94 Integra LS header and a 01 Tiburon Header...
- AHH I HATE EBAY! HELP
- obx headers install!!!!
- CAM and Other Questions
- Sputtering @ Low RPMs
- Ebay (again)
- Hwarang Intake/Exhaust Camshaft
