o2 sensor problems
for the second time now my o2 sensor off the exhaust manifold is throwing 2 cels. i just replaced it and its giving me the same errors not even 30 minutes or 10 miles after replacement, which is an o2 malfunction and an o2 heat error? i forget the actual code numbers now, i think they are 141 and 132 off the top of my head. its also a standard obd2 system. any thoughts?
You'll prolly have to cut the wiring harness off there and solder on some new wiring for it. Do NOT splice the wires, solder them.
QUOTE (Mad-Machine)
also, did you torque it down correctly to the exhaust?
i left it snug but not over torqued if thats what your asking
