Tib Tranny vs. Elantra Tranny??!?1
Old Jan 6, 2005 | 04:32 PM
sharkev's Avatar
Default 2 questions
Hi there..... these two trannies ( manual tranny ) are the same??!....
I know that the engine of the Elantra is the same as the Tiburon both mod 2000...... so there is a diference between these two, or are the same.....
and if there is a diference wht is it?!...
thanks....
Old Jan 6, 2005 | 04:33 PM
a_gut's Avatar
Default Re: 2 questions
I was JUST doing a search on this...
http://www.hyundaiaftermarket.com/cgi-bin/...c;f=40;t=000263
Old Jan 7, 2005 | 07:04 AM
sharkev's Avatar
Default Re: NEED SOME MORAL SUPPORT, FROM FELLOW OWNERS!!!
so.. the elantra 1.8l or Tiburon 1.8 tannies are the best, beacuse de ratio, right??.....
but does the 1.8 L tranny fit a 2.0 L block that easy??!...
or does it need something to fit???.....
and can anyone can be patient and explain to me what means wear/tear???
thanks
Old Jan 7, 2005 | 07:23 AM
Slipstream's Avatar
one question id have to the validity of that thread is what makes them different? is it the gear ratio's or the fdr?
Old Jan 7, 2005 | 07:35 AM
supercow's Avatar
Default Re: FS: RD1 Bros Guages, XG Fog Rings and Tuscani Door Sills
QUOTE (sharkev)
thanks
well another question though is just because the 1.8l tranny has a little shorter gears is it really going to be any faster? especially if you do any major mods, it'll make you shift more often which I'm betting will even things out. plus by going with the 1.8l you going to lose a few mpg, and if this is a daily driver as well then you'll want to take that into consideration.
Old Jan 7, 2005 | 08:58 AM
Jaws021's Avatar
Default Re: F/S OZ-Flow BBTBs and Phenolic spacers
the 1.8 does have shorter gearing... for those that are turbo, thats a nightmare.
I currently have an 03 elantra tranny, and i love it. Nice gas mileage and will give me a slightly longer 4th gear.
Yes they will all fit.
Old Jan 7, 2005 | 12:27 PM
sharkev's Avatar
Default Re: Mitsubishi->Hyundai engine swaps??
QUOTE (Jaws021)
why are you saying its a nightmare for the turbo ones¿??!....
Its better have a longer gearing in turbos?....
and how much millage gets worst with the 1.8L tranny?
Old Jan 7, 2005 | 12:42 PM
MAXXTIB's Avatar
Default Re: Big Hyundai meet in the works
I would say it's a traction problem the shorter gearing will mean more tire spin, I get tire spin in 1st,2nd & 3rd and the shorter gearing would only make it worse.
A turbo car makes more power and can take advantage of the higher gearing.
Old Jan 7, 2005 | 01:25 PM
Slipstream's Avatar
Default Re: About the 1.8 L cam
4g63 transmissions are direct replacements as well arent they?
the beta1 ralley cars used evo trannys
Old Jan 7, 2005 | 02:36 PM
hamhead's Avatar
Default Re: 97 & 99 Tiburon part out
4G63s are not direct swap, engines or transmissions. For god sakes, get this Mitsubishi to Hyundai thing out of your head. Eclipse trannies are on the other side, and Evo ones are AWD, and messin turning that into FWD creates evil little problems.
The 2.0L already has a horribly short first gear. Swapping to a 1.8L is just going to make it worse. Most people that turbo 2.0L or even basic bolt-ons probably want a longer first gear, not a shorter one. lol.gif
