Engine boggs
Old Sep 29, 2004 | 12:03 PM
Gspeed22's Avatar
Default Re: Santa Claus: A Scientific Perspective
Hey im new here,
I recently bought this car, and started to notice the engine boggs out when started in the mornings. Its get to the point where the car alomost stalls. I basically have to but her in neutral and rev it. Sometimes even when its warmed up it does it.
Just wondering if anyone had recently problems.
Any help would be great.
thanks
Old Sep 29, 2004 | 12:10 PM
Casper's Avatar
Default Re: Results from tonight's race :)
Is your car stock? How many miles? Ever run enjector cleaner through her?
Old Sep 29, 2004 | 12:22 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Yeah REDZ loves recommending B12 Chemtool lol.gif I guess it works great. Wait til your low in fuel and put in a full can, then fill up, and run it dry again. I'm not sure if we can get it around here though. I haven't seen it, but any cleaner will do the job.
Old Sep 29, 2004 | 12:33 PM
tibwrcsbj's Avatar
silver, i think you are also supposed to change your oil after using chemtool.
Try the cleaners first, then check your Throttle body (b/c the cleaners never hurt ;-)).....the idle adjustment screw may need to be adjusted.
Old Sep 29, 2004 | 12:53 PM
Default Re: quick pics ... rd1
oops.gif I think I'm done for the day.
Old Sep 29, 2004 | 12:55 PM
wattsup4800's Avatar
Default Re: Engine boggs
was the prior owner using that car on a day to day basis or was the car sitting. Also, im assuming its cold when you start the car, which could have something to do with it.
Old Sep 29, 2004 | 06:42 PM
b12 Chemtool is the SHIZ!!!
Keep up the good word.
LOL
Anyways, the biggest problem is that you are prolly too hard on the gas when the car is cold. Be gentle.
Old Sep 29, 2004 | 09:23 PM
Gspeed22's Avatar
Default Re: Removing dealer badge
the car has no mods its bone stock, has 120,000 km.
I will try some injectors cleaner. But whats weird is that it boggs out when its warmed up.
could it be a fuel pump, maybe a sensor?
thanks
Old Sep 29, 2004 | 09:25 PM
try reseting ECU
Old Sep 29, 2004 | 09:32 PM
Casper's Avatar
Default Re: car show today in ashland!! 9-18-04 UPDATE pictures adde
a clogged injector dosnt care if the car is warm smile.gif. I would try the injector cleaner before anything else... sensors can get pricy (esp the throttle pos sensor).
