Engine swap
Vehicle: Hyundai Coupe 2.0fx RD2
Engine swap
I have a 2000mod coupe with 1.6 engine .and 5-speed gearbox ,,this is a alpha engine right?
can i switch to a 2.0 engine to my car without any kind of problems? what about ecu and wiring?
some tips would be nice ... and i live i europe-norway ...my engine is MAP based. rolleyes.gif
I never heard of a tiburon with a 1.6L, do u mean the 1.8L. If it is the 1.8L i did a few mesurments between the two. They seem to match up. As for wiring and everythign, your going to need someone else on that.
Good luck though....
For the 1.6L, I'm not sure man.
I belive it is the Alpha though.
Post this question at www.kspec.com 's forums, David can answer most of this for you.
yeah it works. i don't know the details but i plan on doing it too. go to www.hyundaiperformance.com and look in the hybrid forum
Speed-Factor : Thanks man , btw ...if i can swap to 2.0 engine without any problems ,, what about turbo kit ? for the 1.6? will it fit? and do i need 2.0 wiring or can i use 1.6?
hm ,as i know the 1.6 is alike 2.0 in size ,,just the ccm is smaller, but remain answers to ,,,wiring and ecu with a engine swap to 2.0 .. i hope i just had to switch engines ...same wiring to both ..but just had to use ecu from a 2.0 ..sorry for the bad english ..
