squeeeeealing
Old Jan 10, 2005 | 11:40 PM
cdogtibby1's Avatar
Default squeeeeealing
got some squealing comin from the water pump??? haha im not sure what that thing is... im a noob when it comes to engines.
yea yea... thats an old engine shot, havent updated forever. ok... the squealing is coming from that... its coming from the pulley im sure of it... "why is he so sure" you ask to yourself.... cuz when i spray wd-40 on it it stops... for a lil while... then it comes back. ITS ANNOYING. HELP ME
Old Jan 10, 2005 | 11:44 PM
I've tightened mine several times and it just won't stop! Anything else I can do? It only happens when the engine is cold... once it warms up it's fine... but when the car starts cold, it squeels for about 15 seconds.. .then it will squeel everytime I turn the wheel OR if I turn the A/C on
Old Jan 10, 2005 | 11:45 PM
cdogtibby1's Avatar
bolt on top??? u mean the one thats on the bracket? i cant quite remember which bolt you are talking about.
is it this one?
Old Jan 11, 2005 | 12:07 AM
cdogtibby1's Avatar
thanks brah.... haha ill do that tomorrow b4 work
Old Jan 11, 2005 | 01:06 AM
Hobgoblin's Avatar
Vehicle: 2015 Subaru WRX
Be sure to update how this works for you! Im having the same issues...
*sigh* Does anything on my car work for more than 1000 miles? LOL
Old Jan 11, 2005 | 01:08 AM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Perform this troubleshoot to find out exactly which component has the binding bearing:
Loosen the belt on each of the accessories one by one, and then start the engine after each accessory belt has been loosened. Loosen the belt just enough to allow the pulley to spin freely with no resistance. When the squealing stops after a certain accessory belt has been loosened, inspect that unit for bearing wear. Good luck.
Old Jan 11, 2005 | 01:10 AM
Hobgoblin's Avatar
Nice, something to do after work today!! heh
Old Jan 11, 2005 | 08:38 AM
Slipstream's Avatar
well if you tighten the belt and throw some dressing on there it'll help but if you have lightened accessory pullies then its going to sqeal all winter long heh.
