timing belt
Old Nov 22, 2004 | 08:52 PM
s2h0a0n6e's Avatar
Default Re: FOR SALE!!!!!!!!!! catback exhaust... head ahh (top end)
i think my timing belt is messing up what shoudl i do im gunna take it to a shop tommorow....but like how has this happened to other ppl??
Old Nov 22, 2004 | 08:54 PM
CyberShark's Avatar
Default Re: Gauging interest for RD exhaust system....your choice.
Get that thing replaced ASAP..IF it breaks on you while your car is running, all sorts of bad stuff will happen and you'll need a new motor!
Old Nov 23, 2004 | 09:16 AM
UltraTibby's Avatar
Default Re: S-AFC II base settings
What makes you think it is "messing up"? A timing belt doesn;t mess up for the most part. It works until it breaks. There isn't really a middle area....
Old Nov 25, 2004 | 11:47 AM
Default Re: new motor gona na tune.. no more FI for me.. what can i
I have to wonder what makes you think that as well. HOWEVER, I have been on a search for a while about the recomendation for timing belt tensioner bearing replacement. Coming from italian cars, the recommendation is every other timing belt change (don't laugh, they only last 25,000 miles on the 124,125,132 series engines in the fiat/lancia/alfa range). I HAVE seen what can happen when the bearing goes and either seizes or falls apart. Very much the same as a failed belt.
Old Nov 25, 2004 | 11:49 AM
UltraTibby's Avatar
Default Re: Help me choose: Stock or New wheels
I am getting ready to replace my belt and I am also replacing the Idler and Tensioner. Both of them together are abou $50 so it doesn't make any sense not to change those out while you are in there.
Old Nov 26, 2004 | 06:45 AM
well.. another thirty thousand miles or so.. and I will be needing another timing belt. I might even replace it sooner if I decide to put an adjustable cam pulley in.
