How to clean engine?
Old Feb 6, 2005 | 03:36 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
Default How to clean engine?
What is the best way to clean engine?
Old Feb 6, 2005 | 05:39 AM
Tiburonmoo's Avatar
Vehicle: 2000 Tiburon
Buy a can of engine degreaser and spray it all over the engine and that will break/get rid of the big shtuff. You can get it from autozone. It's great shtuff. This sound really bad but I go and do a quick mist/spray with my garden hose over the engine after the degreaser. Then if your really meticulous bust out the toothbrush and scrub!
Old Feb 6, 2005 | 06:44 AM
CyberShark's Avatar
I use WD40 on the hoses...its' supposed to make them last longer. I've even used it to clean the engine department when I've run out of degreaser..works OK..
Old Feb 6, 2005 | 08:02 AM
hamhead's Avatar
WD-40, brake cleaner, gas... endless options. Brake cleaner is some strong stuff. My advice is to tape a straw on the end of the brake cleaner cap where the little spray hole is, so you get a more concentrated spray and it doesn't go everywhere.
Old Feb 6, 2005 | 08:11 AM
97blacktib's Avatar
some type of spray you can buy for like under 5$, cleans the motor gives it a much cleaner look. can get it at wal-mart.
Old Feb 6, 2005 | 08:19 AM
CyberShark's Avatar
I even had a friend that used some sort of tire cleaner. I had my doubts but it did a good job
Old Feb 6, 2005 | 09:33 AM
Dmitry's Avatar
In Ukraine in car wash they offer to clean engine. But after cleaning (with spray or other detergents) they use water under high pressure to wash it.
They do not guarantee that your engine will start after that wash.
I'm afraid to clean my engine this way :-/
Old Feb 6, 2005 | 11:15 AM
Alex01tib's Avatar
i cleaned my engine a little while ago.. i used gas and an old toothbrush.. works good, but i had some spots on my heatshield that wouldnt come off even with lots of gas and lots of scrubbing
Old Feb 6, 2005 | 11:24 AM
hamhead's Avatar
Alex, I would definately try some brake cleaner with the little straw. Just don't get it on your paint... because it'll eat it pretty fast.
Old Feb 6, 2005 | 11:27 AM
Alex01tib's Avatar
allright thanks, ill try it when i go home this weekend...oh and ill take pics of how well my intake manifold came out when all i used was gas. it went from brown/grey to very bright grey...
