PDA
View Full Version : Engine, Intake, Exhaust
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Belt Question... Having Problems
  2. Advice Please
  3. Redline Oil
  4. Auto Trans End Clutch
  5. Faulty Pressure Plate?
  6. Someone Help Me Pick A Clutch
  7. Inside The Valve Cover Question.
  8. Another Swap Thread
  9. Auto Trans Problems
  10. Bent Axle
  11. Clutch Alignment Tool
  12. Smoke In Oil
  13. 5th Gear
  14. Oil
  15. So I Need A Tranny/clutch Now
  16. Time For A New Motor Mount
  17. Help, Noise Comming From Clutch!11one!
  18. Lumpy/lopey Idle
  19. Installing Cai
  20. Power Steering
  21. Another Clutch Engagement Thread
  22. Ignition Without Spark Plugs?
  23. Air Temp Sensor In Intake
  24. Clutch & Or Flywheel Issues!
  25. Timing Belt Question
  26. Engine Overheating
  27. Engine Dress Up Kit?
  28. Stroke Kit ?
  29. Should I Tell A Difference
  30. Obx Crank Pulley
  31. In Desperate Need Of Help Removing O2 Sensor
  32. Landshark's Beta 2 Tranny Swap
  33. Trans Cracked, Leaked Oil
  34. Burning Too Much Oil And I Don't Know Why!
  35. Lsd Obx ?
  36. Clutch+flywheel Installed !
  37. Evap Question
  38. New Clutch Is Slipping
  39. Air Filter
  40. Stock Cat Debate
  41. I Have A Few Questions On Manual Tranny Swap
  42. Is It Worth It To Ballence A Flywheel?
  43. New Seco Brand Clutch?!?
  44. Engine Balance
  45. Power Steering Removal
  46. Starter Location On A 2000 Hyundai Tiburon
  47. Need Help With 2 Cel Codes
  48. Map Based Engine
  49. Shitty Gas Mileage, Help!
  50. O2 Sensor Removal
  51. Sharkracing 268 Intake/exhaust Cam Install
  52. I Sucked Up The Sea In My Cai
  53. Vibrating Clutch Pedal
  54. Missfire! Any Other Suggestions?
  55. Motor Problems
  56. Confused About My Motor
  57. Interference Motor?
  58. I Have An 01 Tiburon Need Help With 1/4 Questions
  59. Here Is A Sound Clip From My I/h/e
  60. What Am I? (hose)
  61. Oil Test Results Are In From Blackstone Laboratories
  62. Ebay Alert: Cams
  63. Intake Question
  64. Car Stalls, Won't Start
  65. Awd
  66. A Couple Of Newbish Questions
  67. Throw Out Bearing
  68. F1 Racing Flywheel
  69. Exhaust Question
  70. Spec Clutch
  71. Difference Between Beta 1 2.0 And Beta 2 2.0
  72. Weird Sound After Going Through Large Puddle
  73. Clutch Going Out
  74. Manifold Heat Shield...
  75. momo setup for intake manifold
  76. Uh Oh....
  77. Automatic Starting Off In 2nd Gear?
  78. Crush Head Gasket
  79. Tranny Problems And Need Help On Removing/bypassing The Factory Alarm System
  80. Down Shifting
  81. Belts making noise
  82. Engines For Tiburon
  83. 05 Elantra 2.0l Engine
  84. Which Head Gasket Better For Boost
  85. Fuel Line Clamps.
  86. Tranny Question
  87. Bim, Bbtb, Phenos
  88. P0121, And Other Small Issues.
  89. What Size Wire Runs To The Alternator?
  90. Car Won't Start (fuel Pump)
  91. Clutch Problem
  92. Itb's, I Want These Sooo Bad
  93. Need Help! My Tibby Stalls !
  94. Beta1-98 To 00 Is There Any Differences At All
  95. Arp Install?
  96. Flywheel Question ?
  97. Cams Are Here!
  98. Tranny Going Bad?
  99. Moisture In Plug
  100. EvoFusion Exhaust
  101. Fidanza Guys! Come And Help
  102. Car Will Not Idle, Help!
  103. Airram Hose Function
  104. New Clutch And Flywheel Are In Now
  105. Transmission Blew Up
  106. Hesitation, And Misfire
  107. New Airram?
  108. Fidanza Guys Come !
  109. Clutch Wont Disengage, Help!
  110. New Clutch !
  111. Cam Bearings
  112. 3 Pressure Tests 2 Radiators 1 Thermostat And Wtf?
  113. Look What I Got Today!
  114. I Can't Read This.
  115. Bomz Cai
  116. A Quick Noob Question
  117. Are There Any Aftermarket Coolant Hoses That Fit?
  118. Who Try The South Bend Cluth Tz Serie And Dxd Serie ?
  119. Font Mount Cai
  120. 2000 Tiburon Engine Shaking When Air Is On
  121. I Did Serch
  122. Starting And Idling Troubles
  123. What Do U Guys Think
  124. How Much Hp From Aftermarket Headers?
  125. Mad Jon
  126. Clutch/tranny
  127. Ark Short Shifter
  128. Elantra Vs Gk
  129. Whats Better For The J2
  130. Possible Clutch/transmission Problem
  131. Gas Question
  132. Differences In Transmissions
  133. Most Likely My Stupid Tps.
  134. Clutch Pedal Doesnt Want To Go All The Way Down
  135. A/t Transmission Clunks Hard When Downshifting?
  136. Auto Shifter Stuck
  137. Ticking Noise, Oil Light
  138. Last Thread Before I Do My Clutch
  139. When You Change Your Clutch...
  140. Can I Do This?
  141. Yay
  142. Fal Fans Not Turning On?
  143. Problems Fitting Ssa 4-1 Headers
  144. Radiator Problems
  145. Shifter Play
  146. Bore Question
  147. Hvac Problem
  148. Annoying Buzzing Noise When Key Is Turned
  149. Massive Moisture? How's This Possible?
  150. How Do You Know If The Starter Is Going Out?
  151. Coil Pack Help!
  152. Intake Manifold Options?
  153. Last Queston About My System Upgrade Bbtb From Seoulfulracing.
  154. New System Upgrade 60mm Bbtb Issue
  155. Took Out Cps, New Problems Arise.
  156. Aftermarket Cams
  157. Those Of You With Bbtb's What Gasket Did You Use?
  158. Oil Filers
  159. Tranny Questions
  160. Ark Sts Installed !
  161. Gk Engine In An Rd?
  162. Advice On Head Build-up.
  163. Wt Betaii Engine?
  164. Anyone Know A Place To Buy Engine/tranny Combos?
  165. Reving Question
  166. Clutch Grind At High Rpm
  167. Help Me Now Please!
  168. Drivers Side Drive Shaft Questions.
  169. Clutch Release Shaft Upper And Lower Bushings
  170. Just Installed = Maintec Gt Headers. *New Problem*
  171. Quick Where To Shop Question...
  172. I'd Like A Firmer Clutch Pedal
  173. Tranny
  174. Ignition Switch
  175. So Yeah... My Clutch..
  176. No Fuel Filter On 2001tibby ?
  177. Need Urgent Help
  178. A Few Question On Some Soon To Be Buys
  179. Troubleshooting 1.8 Ecu
  180. 60mm Vs. 65mm Bbtb
  181. Tuning Our Computers
  182. Bent Drive Shaft?
  183. My Ecu
  184. Cai Touching Battery: Sparks?
  185. Hla Reconditioning Or Replacement
  186. Why Is My Engine Better Than Before With New Timing Belt?
  187. Transmission Update
  188. Why Are My Two Air Ram Intake Manifolds Diffferent?
  189. Changing Your Own Clutch
  190. Transmission
  191. Want Your Timing Belt Cover Opened For Access To The Pulley?
  192. 2001 Engine Swap
  193. Buying New Clutch & Flywheel
  194. Can Of Engine Restore: Yay Or Nay?
  195. Rebuild Or Swap
  196. Do You Want A Set Of Crower Cams For Na For $400
  197. 1.8l Ecu Report
  198. Engine Swap
  199. Pictures Of 1.8 Cam Swap
  200. A Few Questions...
  201. Exhaust Vids.
  202. Can Someone Explain Operation Of Iac?
  203. Motor Flush For Turbo?
  204. Should I Get A New Motor Or Replace The Parts?
  205. Idle Control Valve
  206. Short Shifter Question
  207. Got My Car Back
  208. 1995 1.8l Camshaft
  209. Wiring For Ford Tb Install?
  210. O2 Sensor
  211. Auto-manual Device From Level10
  212. A Couple Of Questions
  213. How To Hook Up An Oil Catch Can..
  214. Engine Problems
  215. Clutch Engage Problems...
  216. Clutch Not Grabbing Fully.
  217. Question About My Engine Life
  218. 1st Gear Issues, Need Input.
  219. Reverse Disappeared?
  220. Squeeky Power Steering With Aftermarket Pulleys?
  221. Vroo...spit Spit....ooooo...spit...m
  222. Clutch Problem
  223. Ebay Crap
  224. Throttle Body Sizing......
  225. Check Engine Light.. Only When Its Below 20
  226. Help-horrible Noise Coming From Belts!
  227. Rd1 To Rd2 Shift Surround
  228. Crossover Engine/tranny
  229. Very Useful Timing Belt Info
  230. Tighten Clutch
  231. 5spd Swap Complete! - No Brake Lights, Voltage Problems, No Cruise
  232. What Do You Think Of The Atp Turbo Exhaust Solution?
  233. #4 Spark Plug With Oil
  234. Is This Bad?
  235. Short Throw Shifter
  236. Timing Belt Question
  237. Parts Upgrade ... Rd2 To Rd1
  238. Vibrations
  239. P0335
  240. Betai To Betaii Motor Compatability.
  241. Obx Headers
  242. 02 Sensor Bung In Flexpipe
  243. Yes, Another Flex Pipe Question
  244. Wierd Question
  245. 5spd Swap Done - Car Won't Start - Need Help
  246. Clutch Issues?
  247. Whats With Those Vortex Generators?
  248. Oil Pan.. I Hate It..
  249. Transmission Going?
  250. Exhaust Parts
