Wiring For Ford Tb Install?
Old Feb 12, 2007 | 12:10 PM
Call_to_arms84's Avatar
Im working on the Ford 4.6l thottle body install on my Beta, I have the mechanical side of it figured out and it is in the works but im pretty much clueless about the wiring. I plan on making an adapter plug to allow the ford TB to plug into my stock wiring harness without splicing into it, I can get the plug, i just dont know which wire goes to which. Can someone who has done this tell me what they did? If not can someone shoot me a link on how to figure it out myself, I have a multimeter and I can use it, I just dont know what im looking for. This will run without a CEL.... right?
Old Feb 12, 2007 | 12:44 PM
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
I will post the pins later today for you.
Old Feb 12, 2007 | 02:29 PM
you mean with the tps right?
and yes, you should not get a cel. it will basically act the same. the computer will never even know its there
Old Feb 12, 2007 | 02:56 PM
Tibbychick's Avatar
hey do you talk to spikie (Jerzy) that often? He did this mod recently himself, i think his install went smoothly, you should ask him if you can get a hold of him.
Old Feb 12, 2007 | 07:25 PM
once you get this done you should do a DIY with partnumbers and pics. i could find that TB at the yard pretty easy. will that mod still accomadate cruise?
Old Feb 12, 2007 | 09:28 PM
swap over the pulley and it will. im looking for a tps for one of these if anyone knows where one is
Old Feb 12, 2007 | 09:43 PM
Here is a quick drawing that I did for this, if you have any questions please ask.
And here is an example of the 70mm Mustang TB I have on my car.
Link
Old Feb 13, 2007 | 04:32 PM
thanks tim, I kinda assumed it would be you who would have firgured it out. I asked Jerzy and he said he could not remember. Tim, did your throttle body have a little 3/16" hole drilled in the butterfly? if so will the car idle properly on it? without the idle controler I mean. Tim, would you consider selling a flange for the ford throttle body by itself? Thanks guys
