Bim, Bbtb, Phenos
Vehicle: car
So, since you can't get AIR RAM manis anymore, I guess I'm going to port and polish my stock mani, and bore it out.
So, questions...
1.) What is the stock bore on an intake manifold for a beta1 2.0l
2.) What is the stock bore on the TB for the beta1 2.0l (I think I found it was around 51mm)
3.) What should I bore my mani out to?
4.) What size BBTB should I get to match it?
5.) What does getting a different pulley on the BBTB do for me?
6.) Are Pheno Spacers just a bolt on type deal, or would I have to cut pieces of it one I bore my IM and get a new TB?
After all this, I think that should be everything I can do to the intake end of my car. Next is exhaust, but I plan on getting a header this month anyways. As of now I have...
True AEM CAI
1.8 ECU (the best one)
1.8l cam that was brand new
So that should be about it. Thanks in advance for all the specs guys, I searched for about an hour and a half or so, and I couldn't really find anything useful. I found lots of stuff about swapping TB's and IM's, and putting in phenos and the gains, bust nothing ahout bores except in one post, which only included the TB bore, and I don't even know if that was right.
Thanks guys!
So, questions...
True AEM CAI
Thanks guys!
This is all over the site. It's at like 55MM. I posted pics of it, measured, in Tim's IM thread.
This is also posted all over the site. It's at 54MM, plus or minus a bit depending on who measured it.
The size of the largest BBTB you'll put on there.
Whatever size you think would work best. I'm running a 65MM Tigerlilly, with no ill effects.
Not much. A SMALLER one will decrease the time and increase foot effort it takes to turn it, speeding up acceleration slightly. Other than that, you can add one for Cruise.
Pheno? Phenolic. Yes, they are a bolt on type deal. Go read the DIY for them.
