So Yeah... My Clutch..
Old Mar 6, 2007 | 08:26 PM
ok, when i let my clutch out, it sounds like its rubbing something.. i dont know whats rubbing, or why, but when i let it out all the way it sounds like its rubbing against something..
any ideas what this would be.. when the clutch is pushed in, nothing, but when i let the clutch out in neutral, it makes a sound like its rubbing as its spinning.. i dont like this damn sound.. low fluid in trans? clutch needs adjusting?
i have no clue..
help.
Old Mar 6, 2007 | 08:29 PM
sound like clutch or gears?
ya know you can check the gear oil in .8 seconds and eliminate that possibility. wink1.gif
i think you're going to be yanking your tranny off again.
Old Mar 6, 2007 | 08:30 PM
where is a good place to check the gear oil?
i aint taking the f'in trans off again dammit.. lol clutch is brand new, and has less than 600 miles on it.
Old Mar 6, 2007 | 08:32 PM
the filler bolt. take it off, stick finger in.
maybe theres a stick on it, cant remember.
Old Mar 6, 2007 | 08:34 PM
StrikeEagle's Avatar
Old Mar 6, 2007 | 08:35 PM
lol, i forgot, i knew about the filler hole, but i was hoping there was a easier spot dammit, and i couldn't remember if there was lol..
Alex01tib's Avatar
by "stick" you talking about a dip stick type thing? if thats what you mean then no your mistaken. its just a bolt.
Least you got that job to pay for whatever broke this time eh? lol
Old Mar 6, 2007 | 08:37 PM
lol, but does that sound like it would be a gear thing, or a clutch thing.. anyone know.. i duno how it would be a clutch thing. i know im a lil low on fluid, i need to replace and axle seal thats leaking a bit.
yeah i knew there wasnt a dipstick, but thought there was maybe like a protrusion on the end of that bolt.
Check to make sure your axel is pushed in all the way until it clicks. I had the dealer work on my car and 20,000 miles later the axle worked its way loose. Apparently the clip wasn't clipped inside the transmission where the power comes out. It made a rubbing sound.
