So Yeah... My Clutch..
Old Mar 6, 2007 | 08:39 PM
but was your axle making a rubbing sound when the car was stopped? cuz i dont think it could.
i popped an axle out before, i leaked alot of fluid, lol.
Old Mar 6, 2007 | 08:43 PM
Old Mar 6, 2007 | 08:44 PM
lol, that was like a million years ago, i was like SHIT, there was SOO much fluid on the ground.. o man, i freaked, then i popped it back in and drove the car like 1.5 qts low until i boosted lol.
Old Mar 6, 2007 | 08:52 PM
^^ did you notice the car shifts easier and grinds less with no fluid?
That's kinda an odd problem you're having. does it do it in each gear? are you able to check the fluid level now?
Old Mar 6, 2007 | 08:58 PM
ill check the fluid level tomm.. the gears have never ground, but it seems like its a lil harder to shift, but NO grinding.. i duno. im hoping its just a low fluid level, cuz i aint pulling the trans off again..
the ONLY time i notice anything strange is when im sitting there idling and the clutch is let out, i can just hear like a rubbing sound almost like the clutch is engaged but not in gear, its weird.. i could try and get the noise on camera but the engine noise may override it.
Old Mar 7, 2007 | 04:33 AM
javageek's Avatar
Is it more like a scuffing sound? When it is making the sound push in on your clutch pedal and let off real quick. Does it go away?
Old Mar 7, 2007 | 11:27 AM
yes it does go away the minute i push on my clutch.. sometimes it goes away and sometimes its there..
Old Mar 7, 2007 | 03:00 PM
javageek's Avatar
Mine does that occasionally too. I know I need a new clutch soon though. You already have a new one so I dunno.
Old Mar 7, 2007 | 03:20 PM
demon_fox's Avatar
Vehicle: 2000 hyundai tiburon
try adjusting it if your fluid is fine. i swear if you break it im not breaking another pry bar. lol. jk but yea try adjusting underneath your clutch pedal. did you adjust it when you put the new one in? i cant remember.
Old Mar 7, 2007 | 03:28 PM
Loose or damaged transaxle and engine mounts
Tighten or replace mounts
Inadequate shaft end play
Correct end play
Worn or damaged gears
Replace gears
Worn or damaged bearings
Replace bearings
Use of inferior grade of gear oil
Replace with specified gear oil
Low oil level
Replenish
Inadequate engine idle speed
Adjust idle speed
