Clutch+flywheel Installed !
Vehicle: 2011 Sonata Turbo
So yesterday Me and a Freind intalled the clutch a bought (exedy oem replacement) and the gripforce flywheel from ebay wich they say weight 11lbs but actualy would be 10lbs....
the stock flywheel would be 16.4lbs
so everything went well
i removed the restrictor plate in the master cylinder as well
at first i love it the car go so mutch better feeling of the clutch is alot better and fasther to then with the restrictor plate smile.gif
Good for you. Sounds like alot of fun. I'll be doing my clutch in the next week or two. I've got parts here waiting on install.
was fairly easy job to the old one was pretty rusted and stuck there but we started at about 8h30 and finish at 12h30 with bleeding the cylinder and everything
i say to everyone who haven't removed that restriction plate do it now tongue.gif !!!! the diffrence is unbelivable
QUOTE (sciphi @ Jun 11 2007, 02:42 PM)
Which flywheel did you get? And, did it have a 41mm center hub?
Yeah, that slave cylinder mod is really nice. More positive engagement.
i got the gripfroce from Ebay they say 11lbs but it really was 10lbs smile.gif
beleve to be 35mm !!!
Vehicle: 1999 Hyundai Elantra
Bump.
I ordered the XTD flywheel from Aimco on Ebay. It's going in with an Exedy OEM clutch. Hope the flywheel gets here soon so I can do my clutch. Slipping around town, takes a little bit at the same speed before it engages fully.
very nice, i think a good aftermarket clutch, and lightweight flywheel are your two best mods. i actually had mine done before i even had an intake or exhaust!
but i recommend the fidanza flywheel. mainly cause its even lighter, and the friction surface is fully replaceable fing02.gif
The Fidanza is also about $300-400. The XTD cro-moly flywheel (XTD) was $200 shipped. And it's a 41mm crank! Never see those on Ebay anymore!
I didn't want to dick around with taking the old flywheel off and taking it to a machine shop that may or may not do a good job resurfacing it. Much rather bite the bullet and get a new flywheel, even this one will be better than stock. Plus I intend this to be the first and last clutch this car gets! Well, maybe at 240k miles...
