- motorcycle muffler
- Boring out TB and IM
- !.8 Intake Cam On 2.0 Beta
- Serious Cam Timing Issue!
- Wiseco Pistons
- rid of buzz with resonator
- Injectors
- pistons
- LOL...WTF is a juice chip???
- to stainless or coat..
- '01 Is My Starter Dead? If So Im Having A Hard Time Trying To Remove It
- Anyone Got A Head Torn Open And Some Calipers Handy?
- Short Shifter Help!
- engine block heater
- Which Mechanic Is Right?
- Automatic Transmission Help
- Platinum Spark Plugs
- Rats, Manual Transmission Leak.
- Transmission Linkage/ Shift Forks Gone?
- rusted exhaust
- P0715 And P0731
- Quick Question
- How Much Torque Can My Transmission Handle?
- Timing Belt Related Parts?
- MAF/ECU/TB/INJECTOR combo advice????
- I passed emissions today, with a gutted cat
- Exhaust clamps
- MagnaFlow cat
- System CAI + Headerback
- Check Engine Light
- Leak Down Test Results - Now With Video!
- Slave Cylinder Shot?
- Should I Swap Motors?
- Story Of My (tib's) Life
- No Spark And No Fuel
- Transmission Concerns
- 97 Fx - No Power, Won't Rev Past 5000 Rpm
- Erratic Overheat
- Auto-manual Swap Concerns
- Overheating & Smoke
- Cylinder Head Bolt Removal
- Alternative Clutch Break In Procedure
- Is my car VVT?
- Anyone Have Any Ideas?
- Water = Cel
- Where To Place The Sensor?
- Car Starting Issues When Started When Warm
- Is There A Need To Adjust Idle
- If The Shoe Doesn't Fit...
- There's A Flake In My Boot
- Port Match/spacers 101
- Replacing Gearbox Oil And Brake(clutch Fluid)
- Ticking
- When Changing A Head Gasket
- Injen Intake
- Throttle Body Sensor
- Tob Install Issues
- Beta Ii Tranny Woes
- Very Rough Idle, Bouncing Rpm's
- New Clutch Problems
- Car Shudders When Putting Manual Into Reverse
- Which Ngk Spark Plugs?
- Can The Beta Transmission Fit Into An Accent?
- Needs Just A Little Blue-ing Up
- Hopefully Not Crankwalk
- Engine And Ecu Compatability And Maybe So General Advice Needed.
- Spark Plug Exploded!
- Issues With New Water Pump (sound)
- Black Smoke, Idling Odd And Two Other
- Tranny Leak (it Seems)
- Injen Cai Vs Aem Cai
- P1128 Code
- Installing New Cylinder Head
- This Sound Doable?
- Clutch Still Squeaks
- I'm No Expert, But...
- Atf On Boost?
- Lightweight Flywheel?
- Compression Test Good!
- Cel Question
- Squeaky Cluth Pedal
- Transmission Question
- Torque Converter Slip
- How Different These Two Clutches Will Feel? Fx300vs Fx400 Clutchmaster
- Beta Engine & Transmission Weight
- 1.8/2.0l Beta Combustion Chamber Volume
- Free Cracked Exhaust Manifold Replacement Campaign
- Aftermarket Oil Filters Cause Engine (hla) Noise
- De-cat Common?
- Transmission, Clutch And Connection Problems
- Just Lost My Slave Cylinder.
- Obx Pulleys
- Pull To Push Conversion. What Are The Benefits?
- Increase Fuel Economy By 15% In A Weekend!
- Spark Plug Gap On N/a Motors
- Exhaust Questions
- 1.8 Cam
- Car Struggles At Cold Start Up.
- My Radiator F'ed Up Yesterday
- Eibach Anti-sway Bar Kit
- Flange Leak Problem
- Ckp At Different Angles
- Beta 2 Transmission Fitment
- Fpr Readings
- Got My Car Back From The Mechanic
- Tb & Im Boring Help
- How Fast Can We Get Our Engines Up Too
- Crank Question
- No More Transmission Woes, For Now...
- possible clutch fix
- So.... My Tibby Is Quite F'ed
- Tranny Problems!
- Higher Rpm Capability On Our Betas
- Spark Plug General Info and FAQ
- I Have A Deal For A 2.0 Engine, Gearbox And Computer
- Red, Did You Take Pictures Of Your Head?
- Shifter Base Issue
- 2001 Elantra Overheted Yesterday
- Engine Knocking After Oil Change.
- New Under Axle Exhaust Idea
- Leaky Head Gasket
- Oil Getting Into Antifreeze?..
- Ecu Help
- Tranny Issue
- Help
- Clutch Frustration
- Why Won't This Stupid Transmission Come Out?
- Interested in Camshafts, looking to buy
- Cam Gear Without Shaft?
- Bb Throttle Body Question
- Engine Skips A Beat
- Rythmic Tapping From Tob
- Transmission Problem
- Crankshaft Problems
- Debating Sign Groves
- Phantom Grip Lsd
- 3rd Gear Issues
- Transmission Problem!
- Spark Plug Cover Bolts Stuck
- Exhaust Manifold - Torque Specs
- Head Gasket Help
- Starting The Car Noise
- Compression Tested Plz Help
- Installing Pistons Yourself
- Idle Rpm's Jumping Up And Down
- Throttle Body Spacer
- Fitting Kfx Equal Length Headers On A Beta2
- Help! Stripped Bottom Bolt From Fuel Filter
- P0303 - Cylinder 3 Misfire Detected
- Auto To Manual
- Washer On Release Lever?
- Engine Temperature Gauge
- Ecu Compatibility?
- Help My Ecu Fuse Keeps Blowin
- Speedo Gone Crazy
- Tranny Issues
- Belt Choices
- Fishing For Advice On A Tranny Issue
- Crank Pulley Bolt Torque Issues
- Vibration At 3000 To 3500 Rpm
- Engine Overheating
- 16k Engine, $400, Yea You Can Say Im Happy
- Name That Sensor
- Yet Another 5-speed Swap.
- Timing Out Of Sync?
- Led For The Dome Light/trunk
- Raising Engine And Transmission Up
- P&p Im And More....
- Infrequent Engine Stumble Tsb
- Exhaust Gas Smell In Car Upon Acceleration
- Test The Acceleration Sensor?
- Help with clutch problems
- Is This Detonation/misfire
- My Very Own Exhaust Build
- Can Not Shift Into 1st Gear!
- Removing Crank Pulley
- Tib Is Dead...please Help! P0304 Misfire
- Finally Got My Overboost Intake Manifold Fitted
- My Car Is Dying
- My Tiby 4g63
- Compression Test
- Flywheel Spacer On Oem Flywheel?
- Cam Sensor Or Knock Sensor? Videos Added
- Cel
- Beta 2
- Xtd Stage 3 Clutch
- Possible Bad Throw Out Bearing?
- Beta Max Na Hp
- 1.8 Cam And Shifting Problems
- Engine Rebuild... With Better Components?
- Cant Get My Exhaust Cam To Move To Get Engine Tdc
- 2.0l Timing Belt Kit-prices
- Aftermarket Ecm?
- New/fresh Beta 1 Motor 1/4
- Yellow Gooo Inside Of The Valve Cover
- Muffler Hanger
- Exhaust Holder
- Squeak From Hell
- Beta2 Intake Manifold Options
- Head Gasket Needing Replacement
- P1128 Ltft Lean In Cold Weather, Triggered By Deceleration/coasting
- Wierd Puttering!?
- Clutch Depression After New Clutch
- Low Compression
- Crappy Headlights?
- Clutch Won't Engage
- Hks Exhaust - Am I The Only One?
- Alternator Tensioner Bolt
- 97 Dohc 2.0 Tiburon Clutch Issues
- Crank And Con Rod Bearing
- Our Blocks Cylinder Coating
- Trans Shifts Fine, Exp Reverse
- Ok, I Got A P0343 Cel
- What Does Knocking Sound Like?
- Cai
- Wierd Stalling Issue On A/t
- Alt. Fuel (lpg) - Vacuum Line ?
- Good Thing I Bought A New Clutch
- Oil Pressure Sender / Gauge ? Need Help!
- Having Problems With My Car For 2 Months...
- Stock Fuel Pressure
- Time For A New Clutch?
- Flywheel Heat Numbers?
- Vacuum Leak
- Beta2 Pcv Valve Problems :(
- Cost Of Head Gasket Repair?
- Valves Ticking
- Cleaning Maf With Electronics Cleaner
- Relocating The Iat Intake Air Temperature Sensor
- Bad Throttle Position Sensor?
- California Emissions Adding Header?
- Headers
- Head Restoration
- Help What To Inspect On Engine?
- Diagnose: Low, Boggy Idle
- Trans Problems
- Car Stalling After 30 Minutes Of Normal Driving.
- Help! Before I Burn This Pile Lol
- Cheap Ebay Cais?
- Piston Rings Question
- A4bf-1 Vs A4bf-2?
- Question About 99 - 2000 Transmission
- Engine For A 2002 Elantra?
- Newb Question
- Engine Idles Very Low At Times
- Smoke From The Hood
- Help! My Car Is Acting Weird
- 83mm Stock Comp. Forged Pistons
