Crank Pulley Bolt Torque Issues
Old Mar 2, 2009 | 09:50 PM
bigfishmoney's Avatar
Been having problems with torqueing a crank pulley bolt to spec without having the car roll back or the crankshaft rotate along with the camshaft. This is near impossible, had my brother come out and he held the brakes even, still rotating, and going back to its original spot after trying.
Should the car be lifted more? How much is this thing gonna give?
Old Mar 2, 2009 | 10:43 PM
It will rotate as long as you don't have anything completely blocking the crank from spinning. A screwdriver in the starter teeth on the flywheel could work. I used a lever holding the timing gear immobile relative to the head (with the timing belt installed) and an assistant hanging off the lever . . . edit I couldn't find where I said how I did it so I added to the end of the timing setting DIY
http://www.rdtiburon.com/index.php?showtop...mp;#entry392460
Old Mar 3, 2009 | 01:46 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
Orrrr hold the pulley with one hand and use an impact gun with the other fing02.gif
Worked for me...several times.
Old Mar 3, 2009 | 02:54 PM
Not recommended, unless you can verify the max. torque output of the gun.
Old Mar 3, 2009 | 03:00 PM
SR Tech's Avatar
Old Mar 3, 2009 | 03:01 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
I had my lady keep the break pressed while in gear
Old Mar 3, 2009 | 03:29 PM
QUOTE (Sea-Ray Tech @ Mar 3 2009, 05:00 PM)
Hyundai recommends that special tool be in their mechanics tool boxes. When I get a actual garage that I can work in, I'll be buying a pneumatic set and a adjustable torque impact adapter. That's the shizzy.
Old Mar 3, 2009 | 04:04 PM
if the car was on a lift the pulley bolt could be torqued to spec if it was turned the total 180 degrees
car lifts are the shizzy
