PDA
View Full Version : Engine, Intake, Exhaust
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25
  1. Revving at a complete stop?
  2. Timing the timing belt?
  3. Blown Clutch?
  4. Everyone with a header come in here !
  5. 6-speed rd??
  6. OBX Exhaust cam gear Yay? Nay? Also Q's on Cam adjustment
  7. Mugen CAI
  8. FINALLY; Production of new gen Hyundai super-engines
  9. Grounding points *happy ending update*
  10. Exhaust Question
  11. stalling problem
  12. K&N problems
  13. Help with my tranny grinding into 5th...
  14. Free Cam Sprocket Mod !
  15. Yes it is yet another clutch question....plz help
  16. which tranny do I have?
  17. high comp pistons
  18. Shops todo work in md/va
  19. Clutch problems
  20. Changing Spark Plugs
  21. air filter + Sport exhaust
  22. SAFC/Bigger Injectors
  23. Mods that you can feel the difference..
  24. Help with Clutch
  25. Injectors
  26. thoughts on airram and bbtb
  27. cel P0304 - Misfire in #4 cylinder
  28. TB and IM questions
  29. Changing intervals
  30. How do you change gear Oil?
  31. Pics of Knock / Accel sensor
  32. Timing belt and chain change at what?
  33. 4-1 header
  34. no idea what the problem is?
  35. Something Wrong with My Car
  36. Clutch question
  37. Oil Change Intervals
  38. clutch adjustment
  39. Oil type?
  40. Shifting into 2nd...
  41. 2nd 02 sensor
  42. Need inlet and outlet diameter in mm of TB and inlet diamet
  43. Question about lighter pulleys
  44. Something broke
  45. Low Idle
  46. RSide Headers
  47. clutch change
  48. Grounding kit???????
  49. Gear Oil, what are youusing?
  50. DECREASE YOUR SHIFTING TIME!!!!!! 4 FREE
  51. 20 WHP from just an intake?!
  52. Stock IM measurement
  53. KORE Exhaust
  54. Timing Chain, or Belt??? now im confused...HELP
  55. intake
  56. Another clutch question...
  57. Need help plzz....
  58. BETA vs 4g63
  59. HELP HYDROLOCKED!!
  60. Burning Clutch
  61. Check Engine Light....HELP!!!!!
  62. FGR question
  63. OBX mufflers
  64. tibby engine swap question
  65. another clutch question
  66. My Custom Made Short Shifter
  67. Stuck in 3rd gear
  68. clutch install
  69. rebuiding a tranny
  70. need some numbers
  71. Tiburon SE 2000 CAI
  72. beta2/1 aftermarket pulleys
  73. Cam Swap
  74. CAI
  75. Need ur opinions on this guys...
  76. evo fusion intake ques ??? on ebay
  77. New computer/fuel system??
  78. Air Ram IM Installation
  79. *Exhaust Listings* Currently Available...
  80. o2 sensor
  81. Cam Belt ?
  82. What is a good way to syphon gas from the tibby
  83. Rough Ride
  84. Need a new dipstick
  85. Veilside Tibs: How are you guys jacking ur cars up?
  86. High Idle
  87. XTD Racing Clutch
  88. where is the engine number located?
  89. Difference between SHORT RAM & COLD AIR INTAKE
  90. * Sparkle * Sparkle How do i clean the engine?
  91. MBRP exhaust
  92. lightweight pulley sets
  93. VHR clutch owners...
  94. ECT Switch on Automatic Car?
  95. loss of power in the upper RPM range
  96. Crank teeth, cam help
  97. Idle Problem
  98. Link between intake and exhaust tone
  99. RSide SS Problem
  100. Custom exhaust systems
  101. HELP with a fault code
  102. Wondering if Nology or Magnecore is better? Read in!
  103. UnderDrive Pulley
  104. Alternator problems?
  105. Backpressure or cheap gas?????????
  106. O2 Sensor question
  107. sound when starting the car
  108. kspec and SR underdrive pulley sets and confusing me.
  109. Recommended clutch
  110. :) :) :) headers... mmmmm
  111. Compression Question...
  112. Injen Cold Air Intake Questions...
  113. auto to manual DIY
  114. ssautochrome headers.... what you've experienced!
  115. 1.8L Intake Cam..... Where to buy?
  116. Intake Cam
  117. MBRP Catback Exhaust System
  118. Header install without haveing to lengthen the 2nd O2 sensor
  119. Cat Back?
  120. Gear oil
  121. i want headers.... but which do i want????
  122. Radiator Fan Not Working
  123. Stock clutch?
  124. Automatic to manual
  125. Air ram intake
  126. air conditioner
  127. Turbo TB on N/A
  128. High Flow Cat?
  129. CLUTCH PROBLEM!!!! EMERGENCY!!! NEED ANSWERS NOW PLZ!!
  130. MSD Digital Multi-Retard
  131. Header
  132. hp summer sale
  133. BBTB installed now I have a CEL?
  134. New CLUTCH!!!!!!!!!!!!!
  135. CEL
  136. Ported and Polished heads??
  137. SSA CAT
  138. hard start
  139. CEL!
  140. auto to manual wiring guide
  141. Bored TB??
  142. Good Cam for a 1.8L engine
  143. cheap a$$ CAIs?
  144. cams and pulley
  145. Slamming your face against the dash when Second is sluggiest
  146. Exhaust
  147. Stand Alone Fuel Convertor
  148. HELP W/ HEADERS...
  149. Any idea how to get off any black marks on headers?
  150. what the hell
  151. 1st gear problems.....
  152. where is the MAP?
  153. faulty speedometer
  154. engines....
  155. AEM intake rubber screw thing
  156. shiftin isnt exactly astroglidey!!
  157. For all of you looking for 4-2-1 headers
  158. AEM intake - which color....
  159. anyone help me out on this pic? found it on a site.
  160. Spark Plug Gap?
  161. ATTN! AEM / BBTB owners... BOV?
  162. Slight vibra at 3500 RPM
  163. OBX short shifter...
  164. Cams
  165. SHORT SHIFTER GOOD OR BAD???
  166. Anybody have a hookup for Borla?
  167. cai
  168. Rattling Sound - Cat Went Bad
  169. True horsepower?
  170. Wrapping Headers
  171. Where can I get a good high-flow cat for cheap?
  172. SSAC header 4-1 chrome!
  173. Fuel Injectors
  174. 01 tib idle vibration
  175. New Radiators - Jaws is too lazy to post here...
  176. New new plugs, Brisk anyone?
  177. Short Throw Shifters
  178. Best muffler for our cars?
  179. Buying headers. Does this look legit you guys?
  180. How do you get xtra HP
  181. Dynos
  182. Finally.
  183. 4-2-1 Header Better or Worse Gas Mileage
  184. HELP!
  185. aftermarket cams and tuning
  186. stock clutch
  187. Auto tranny on the fritz
  188. O2 Sensor with SSAutochrome 4-2-1 header.
  189. tranny and clutch questions
  190. engine code
  191. Power/Speed chips
  192. Anybody has an LSD installed?
  193. Hot
  194. B&M Return Spring Question
  195. great news on quaife
  196. Good Idea, Bad Execution
  197. Oil leakage question
  198. Engine Overheat
  199. Quieting Exhaust
  200. idle a lil off
  201. Short RAM
  202. worried about my tranny
  203. OBX catback
  204. OBX Headers
  205. confused about beta's
  206. need clutch recomendations..
  207. timing belt/warranty question
  208. Oil Viscosity
  209. B&M Shortshifter problem
  210. MAP or MAFS REinstallation
  211. 1.8 Cam swap
  212. tranny flush/fill
  213. How do I know if my engine is Beta 1 or Beta 2?
  214. tranny gone!!!
  215. SSautochrome headers for 1997 1.8L?
  216. About painting the spark plug cover...
  217. ahh help!
  218. oil pumps
  219. how big
  220. Good deal or another Ebay rip off
  221. Fuel Rail Eh?
  222. Valve cover leakage
  223. A few questions
  224. Check Engine Light!?!? WHAT?!
  225. Intakes??? THE BEST
  226. Exhaust Question
  227. Short Shift install
  228. screeching sound when turning wheels
  229. Intake, get a new noise?
  230. What Oil you running?
  231. Loud hum at 40mph and 60 mph
  232. 30k Tune-up Maintenance
  233. Korean spec Tiburon
  234. Adjustable cam sprockets
  235. Airram intake
  236. should i be worried?
  237. What parts would you like to see?
  238. EBay CAI Split Topic...
  239. 5 speed difficult to put into reverse gear?
  240. Miss a gear while shifting.. what happens?
  241. CAI install tomorrow
  242. Question about replacing Auto Tranny Fluid
  243. vvt...
  244. just ordered
  245. GRRRR!!
  246. NEED SOME MAJOR HELP!
  247. tired of the talking
  248. how much power can a oem 5 speed tranny hold
  249. Header Installation
  250. Coolant Filters
