B&M Return Spring Question
Old Apr 15, 2004 | 12:08 PM
5ly2daboneZ's Avatar
Ok I made a post before about my B&M when i didnt know what was the problem. I start new topic because I have a few questions about the problem I actually had.
Here goes :
There is some extra play with the shifter between the 2 ends of the Bolt
Sorta like this
^shifter---^Extra play
I noticed that when I shiftin 2nd, 4th or reverse, it bends backwards in the extra play and PIN doesnt stay between Return Spring but slips underneath therefore not returning to center position. I eventually ripped off the rubber on my return spring so to fix I put a LOT of electric tape so its thick enough the pin doesnt go underneath the return springs
Does this ever happened to any of you with B&M SS? I want to get new return spring and figure out a way without all the tape. How much is return spring / where can i buy one?
Also is it possible to put a washer or 2 in the extra play back of the shifter base to make it sit tight or is this bad for transmission / cables?
Thanks
5ly
Old Apr 15, 2004 | 12:11 PM
javageek's Avatar
I don't have all of that play with mine. I would double chekc your install, make sure the washers are all installed. It has been awhile since I installed mine, so I can't be precise, but something is wrong with yours.
Old Apr 15, 2004 | 12:50 PM
Me neither.
Do you want me to go out and take some closeup shots of my B&M before I take it out?
Old Apr 15, 2004 | 05:53 PM
cdogtibby1's Avatar
i think someone needs to do a full DIY on the shifter install... pics and everything
Old Apr 15, 2004 | 06:44 PM
QUOTE (cdogtibby1)
I just did.
It'll be up in a few hours. Along with comparison photos of the B&M and RSA.
I'm good.
:twisted: laugh.gif
Old Apr 16, 2004 | 05:36 AM
Thank you REDZ you are the man!
But I think i found the problem yesterday. There is a good DIY on b&Mracing.com or whatever the site name...
You know there are 2 plastic pins that goes on the shifter assembly that you take out from stock and put to B&M?
The idiot who installed it for me put the left side one but didnt put the one underneath, so it doesnt keep in place makes it wobble goddammit i should have done it all myself... wasted 20 bucks to get installed something i could have installed my eyes closed in a coma with hands attached
Old Apr 16, 2004 | 08:58 AM
javageek's Avatar
I was going to mention those bushings but figured that wasn't it, dangit.
Old Apr 16, 2004 | 09:02 AM
yeah sometimes its like totally what youre NOT looking for thats wrong that tahts a PITA...
Old Apr 16, 2004 | 09:20 AM
And now that this is fixed, it's locked.
